How do you attach a front tag?
NJ, USA   USA
NJ requires a front license plate, my car (TR8) never had one. Is there a bracket or just drill into the bumper and use screws?
TeeR8 Avatar
Calgary, AB, Canada   CAN
My TR8 was previously registered in Ontario and has two screw holes in the upper part of the centre recess of the front bumper for the front plate; we do not have front plates in Alberta. There was no front plate bracket when my car arrived in Alberta.
You can barely see the holes/marks in the front bumper.
Henri
1980 TR8, Platinum
1971 MGB GT, Midnight Blue
Edited 1 time(s). Last edit at 2017-11-09 04:35 PM by TeeR8.
TR8, VSCCC Breakout, 2013 Apr 27.jpeg    80.5 KB
darrellwalker Darrell Walker
Vancouver, WA, USA   USA
1966 Triumph TR4A "Christy"
1981 Triumph TR8 "Kate"
Here is how I attached mine. There were not any holes in the bumper when I got the car, and I didn't want to make any. I grabbed this bracket from the auto parts store, I think they are often used on trailers, and the black plastic backer plate (which isn't really needed). I then used a large fender washer to secure the bracket using one of the bumper cover bolts. I keep telling myself that I should affix the washer to the bracket, but it hasn't fallen off yet.
This is the bracket, you have to bend it a bit:
https://www.amazon.com/Peterson-428-09-Universal-License-Bracket/dp/B002IVEOR4/ref=sr_1_8?s=automotive&ie=UTF8&qid=1510267165&sr=1-8&keywords=license+plate+bracket&dpID=31s-1Ic0GNL&preST=_SX300_QL70_&dpSrc=srch
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
IMG_1067.jpg    22.8 KB
IMG_1068.jpg    45 KB
POW Peter Wirth
In reply to # 1496983 by darrellwalker Here is how I attached mine. There were not any holes in the bumper when I got the car, and I didn't want to make any. I grabbed this bracket from the auto parts store, I think they are often used on trailers, and the black plastic backer plate (which isn't really needed). I then used a large fender washer to secure the bracket using one of the bumper cover bolts. I keep telling myself that I should affix the washer to the bracket, but it hasn't fallen off yet.
That's very clever. I'd do that except my front bumper was drilled from the get-go. On a slightly different note I believe it was up to the dealer to drill plate holes front AND rear. In the rear my dealer did a crap job with one hole about 1/4" lower than the other so I have to re-drill a hole in the plate to square it up.
In reply to # 1497145 by POW
I also use the same plastic mount on the rear, it has lots of places for holes, so you can get it straight and drill new holes, and not have to mess with moving one of the existing holes. I also like how it set the plate out a bit from the back panel.
Here is an example:
https://www.amazon.com/Cruiser-Accessories-79150-Mounting-Plate/dp/B00032K4VA/ref=sr_1_4?ie=UTF8&qid=1510345991&sr=8-4&keywords=license+plate+mount&dpID=41F6B57QXGL&preST=_SX300_QL70_&dpSrc=srch
Darrell Walker
Vancouver, WA, USA
dhuddleson Avatar
dhuddleson David Huddleson
Manotick, ON, Canada   CAN
I did something similar to what Darrell did, but I used a "factory" bracket from a Gen 1 or Gen 2 Mazda RX7 that has two "arms" that reach under the bumper. I had to "masssage" it slightly to get the angles right, but it looks like it belongs. In my case, the "arms" are longer and I was able to go beyond the rubber bumper cover and simply drill into the metal inner bumper itself (to the left of Darrell's big washer).
robtr8 Rob Stephenson
Lake St Louis, MO, USA   USA
I threw the front plate in the glovebox. There's talk of Missourah going to one plate, I don't think the cops really care, as long as you aren't hooning around.
I took the front plate off my XC90. Similar result.
In reply to # 1503506 by robtr8 I threw the front plate in the glovebox. There's talk of Missourah going to one plate, I don't think the cops really care, as long as you aren't hooning around.
There's way too many revenue-generating radar and red light cameras around here for the police to stop caring!
Darrell Walker
Vancouver, WA, USA
You get ticketed in Oregon without a front plate. <sigh>
1970 Triumph GT6 MkII
