Alternator
Alternator
handspiker Paul Handspiker
Toronto, ON, Canada   CAN
Is there another alternator that can work on a 1980 triumph tr7 2litre engine with Stromberg carbs.Thanks
robtr8 Rob Stephenson
Lake St Louis, MO, USA   USA
https://www.rareelectrical.com/
hfast Avatar
hfast Henry Fast
Selkirk, MB, Canada   CAN
I'm using one from a late 90s Saturn. Try doing a search for some more ideas.
rainking1958 Avatar
rainking1958 Randy Scott
Green, OH, USA   USA
1977 MG MGB "Kermit"
1979 Triumph Spitfire 1500 "The Runt"
1980 Triumph TR7 Drophead
1980 Triumph TR8    & more
The late 90’s Saturn alternator works. You need to replace the pulley. The Saturn has a surpentine pulley
You need a vbelt. The alternator is a Bosch. Same connectors as a gm ac delco. After my second Lucas went bad I made the swap
1966 Triumph TR4A
