Hi every body Triumph Tr7 Door pins
Swordfishdani1978 Giovanni Dilacato
Saltcoats, Northayrshire, UK   GBR
Am looking for door pin for my Tr 7 drivers side upper hinge but bottom pin,
thats fell out Its a 1978 model,
this hinge has 2 pins in it ,can you let me now where i can get a replacement
thanks Toni
In reply to # 1489970 by Swordfishdani1978 Am looking for door pin for my Tr 7 drivers side upper hinge but bottom pin,
thanks Toni
Toni:
This has come up before. The pins were never available separately, you must buy a replacement hinge. Since the hinges are welded, this doesn't help very much. No one, to my knowledge, sells them separately.
You will need to obtain some suitably sized bar stock, and fabricate your own. Sorry, I know that is not much help.
Perhaps someone else has more current information, and will chime in.
MAB Mark B
Cedar falls, IA, USA   USA
Pin diameter is standard size. I think 5/16, but you will need to measure. Buy at auto parts store and cut to length. May have fallen out because hole in hinge elongated. Weld a washer on. Lube pin. Install pin and spot weld to washer. Won't come out now.
1971 Triumph GT6 MkIII
