Need outer door latch.....
Az7fan Avatar
Az7fan Paul Dorman
Tempe, Arizona, USA   USA
Need a L/H outer door latch that mounts on the door...Moss and VB have but only L/H. Have had middling luck with both of these places. No R/H available....any suggestions...would like to replace both....thanks....
Beaverton, Oregon, USA   USA
In reply to # 1487869 by Az7fan Need a L/H outer door latch that mounts on the door...Moss and VB have but only L/H. Have had middling luck with both of these places. No R/H available....any suggestions...would like to replace both....thanks....
You can go used. These guys have a wrecking yard and will sell you one: British Auto Works. NFI.
They will answer your email.
Andrew1966 Andrew Ward
Abbotsford, BC, Canada   CAN
S & S preperations out of the UK. They will ship world wide. They probably have new and used.
1980 Triumph Spitfire 1500
