Carburetor upgrade
Carburetor upgrade
jb4249 Avatar
jb4249 Ted Bush
Highland Heights, USA   USA
I am having the engine on my 1980 TR7 rebuilt. I am considering a few upgrade and looking for any input. I'd like to use dual Weber DGEV carbs with headers and an upgraded cam. Anybody use these carbs or possibly Weber DCOE carburetors and how have they preformed for you?
Thanks, Ted
In reply to # 1486868 by jb4249 I am having the engine on my 1980 TR7 rebuilt. I am considering a few upgrade and looking for any input. I'd like to use dual Weber DGEV carbs with headers and an upgraded cam. Anybody use these carbs or possibly Weber DCOE carburetors and how have they preformed for you?
Thanks, Ted
Honestly, the Zeniths are plenty good for a warmed over motor. The Webers are superior at high RPMS to be sure, but tuning them requires patience and a box full of jets and emulsion tubes, unless someone else has done all the work and has the same motor as you. In that case you can copy their setup. At low and mid RPMs, the Zeniths are an excellent choice, and what you give up at high RPMs is very small on the 2 liter motor. And if you add that cam, turning them to match the cam is much easier than tuning the Webers.
Every motor I have seen with Webers has been poorly set up. Pull a couple plugs and they are sooty black, indicating poor power and fuel economy. A few people manage to get them set up properly, and they will sing for you in the upper RPM range, but where you drive every day not so much.
Spend your money elsewhere for performance. An electric fan, K&N air filter, head work, raised compression, mild cam, header. And after each change you can easily reset the Zeniths with an adjustment tool. If you go totally crazy on performance, you can upgrade the needles easily.
If your engine is being rebuilt, get the euro pistons, a 3 angle valve job, and port work. Those will do far more for you than a pair of Webers.
jb4249 Avatar
jb4249 Ted Bush
Thanks for the input. I have the original Zenith's but the PO had installed SU's. Not sure if they offer more than the Zenith's or not. I will discuss the additional engine work with the rebuilder. It should be in hos hands late next week
Ted
POW Peter Wirth
I agree with Darth, but as far as SU's or Stromberg's is concerned it's probably a wash if either set up is correctly jetted (needled?). I have a TR8 that was fuel injected, now it has a 390 CFM Holley 4bbl. It also has a warmish cam, and 9.65:1 pistons up from 8.13:1. In hindsight I think the increase in HP achieved would have been the same using some Zenith's or SU's with greatly reduced expense. A c.v. type carb is very simple yet works so dependably.
1976 Triumph TR6
