TR5 & TR250 Forum
Painting the chorme on a TR250 and other stupid questions
DMShuman David Shuman
Ithaca, NY, USA   USA
I am in the middle of having my TR 250 restored. Would you change the color? How about the chrome between the fenders. Wasn't this chrome originally painted? Would you paint this chrome? I also understand the bottom of the rocker panel was also painted black. This is going to be a frame off restoration. Would you change the color from Royal Blue? Thanks, David
Edited 1 time(s). Last edit at 2018-02-01 05:49 PM by DMShuman.
jplatel1 jacob P
Albany, NY, USA   USA
1964 Triumph TR4 ~ For Sale ! ~
1968 Triumph TR250
should be painted body color. and i actually like that minor difference/designation over the earlier tr4/4a with the unpainted fender beading.
jplatel1 jacob P
Albany, NY, USA   USA
1968 Triumph TR250
also, if youre doing a stock frame off restoration i would go with whatever color the car left the factory with. and yes the bottoms of the sills/fenders below the trim piece is coated in black chip guard. there are people here who have tried different things and will recommend something
my tr250 is missing the chip guard and i plan to add it back, its just another small thing that sets the car apart from a tr4a, and i think it would be worthwhile.
Bpt70gt Avatar
Bpt70gt Brian T
Westmoreland, NH, USA   USA
Royal blue. Fender trim body color. I did not apply the rocker protection.
TR on 8-20-17 2.JPG    37.5 KB
Ithaca, NY, USA   USA
Good to know that the painted trim sets the car off from a TR4.
barringtonpro Avatar
barringtonpro FRANK BORGES
PASCOAG, RI, USA   USA
1954 Jaguar XK120
1969 MG MGB GT "The Hose"
1970 Triumph TR6
1971 Triumph TR6
So, the fender/hood chrome, front and rear deck, is painted the body color, from the factory?
Is this correct?
wow!
mgruber921 Avatar
mgruber921 Marvin Gruber
Florence, AL, USA   USA
Your car, paint it the color you want. Just remember to do correct job changing color, it has to come down all the way. I like the royal blue but valencia is my favorite on the 250.
Marv
Ithaca, NY, USA   USA
Yes, I was going to go with Valencia blue. It will be a frame off restoration. The car is apart so the color change will not be detected.
TR250Guy Avatar
TR250Guy Tim Moore
Dayton, OH, USA   USA
I'm of the opinion, its your car do what you like. Not what others think you should do. I personally liked the subtle accent the stainless fender beads add to the car unpainted. I have also made numerous other changes to the car because I liked it. Here's a video I made after completing the frame off restoration that shows the subtle accent that the fender beads add. But to each their own.
1968 TR250 "TRminator"
Owned since 1980
Ithaca, NY, USA   USA
I do like the wood caps on the door. Where can you find this item? I looked before with out any luck.
TR250Guy Avatar
TR250Guy Tim Moore
Dayton, OH, USA   USA
I got them from CG Woodcraft. Same company that made the dash. They are also on ebay.
Owned since 1980
palermo russ n
Providence, northeast, USA   USA
Of course, the chrome trim along the rocker panel separating the body color
from the mate black chip guard is Stainless steel - not painted.
M. Pied Lourd Pied Lourd
ON, Canada   CAN
I am restoring a Royal Blue TR250 at the moment. I do not intend to paint the beading. I prefer the stainless look (like I have on my TR3's). To each their own, but yes, if you are doing a concourse restoration, then it needs to be painted.
Good luck with your restoration.
Tush
BraxtonO Avatar
Raleigh, NC, USA   USA
Like others, I realize that the stainless fender bead was originally painted on the 250’s. But I prefer the look of the bright work, particularly on a darker color like my TRG 4A. ( and your Royal Blue is a nice looking car Brian). So I’ll prob go naked SS on my 250 when I get to that point.
I usually do my own paintwork - I’m so-so at best but I can satisfy myself - and honestly I’m a little apprehensive about getting the paint to adhere well to the stainless over time. Never done that before, and fear if it chipped or peeled it would look worse than if I had left it alone. Additionally, with the hood stripe, when I start thinking about the sequence of which pieces to paint when - and having it all line up correctly once assembled - well let’s just say that concerns me. That stripe is complicated enough without adding an extra element of difficulty. I’m sure it can be done (and many have) - I’m not sure I could do it well enough to be happy with it.
I think it’s fine either way. What you like is what’s most important.
Best,
Braxton
1975 Triumph Spitfire 1500
