TR5 & TR250 Forum
Does this wiper motor look right?
Broken Wrench Avatar
Albuquerque, NM, USA   USA
Happy N.Y! The wiper motor works well in both speeds, but the wipers begin their return to horizontal from just past vertical which can't be right. Would be much better if they went farther, especially for the passenger. Neither Bentley or the Masters electrical books mention any adjustability for this which makes me think that there isn't any. Do I have the wrong motor or a problem with the wheel boxes?
Steve
68 TR250 - daily driver
62 TR4
20171230_172139.jpg    35.6 KB
Brian Oklahoma Brian Plotkin
Edmond, 73012, USA   USA
1968 Triumph TR250 "Kevin"
It looks like the correct motor. There is some adjustment of the linkage that attaches to the motor.
Did you try moving the wiper arms on the spindles?
Thanks for the replies guys. The wipers park in the correct position, so their position on the spindles is probably correct. I'll look at any adjustment possible at the cable today. I have the dash apart and window frame lifted as I'm replacing the dash pad. I guess that this would be the time to climb under and inspect the wheel boxes.
Steve
62 TR4
gozto11 Avatar
gozto11 Todd Bermudez
Cincinnati, OH, USA   USA
if i remember right, not all wheel boxes are created equally. tr250 is different than tr6. trf lists different p/ns for each
carpecursusII Drew H
Oklahoma City, OK, USA   USA
That is the correct wiper motor based on serial number and manufacture date. Sounds like a gear problem.
Aphyle2012 Avatar
Yes, it does sound like a gear issue - missing/worn teeth?
