TR5 & TR250 Forum
surrey top
Bpt70gt Avatar
Bpt70gt Brian T
Westmoreland, NH, USA   USA
I agree, way to much $$$ for what they are supplying.
gozto11 Avatar
gozto11 Todd Bermudez
Cincinnati, OH, USA   USA
In reply to # 1501156 by tirnipgreen I just looked at that one on Craigs...
Is the backlight glass seal cut in two pieces...? Where's the chrome trim strip in the seal...? Where are the interior finishing panels...?
Where is the headliner...? The hardtop panel seals look funky. The hardtop panel has the bolts sticking out of it...no captive nuts...!
Where's the soft top...? Where's the soft top frame...?
The paint looks nice...
Just sayin'...Ryals
It’s original...I recognize the trim on the backlight. It’s ancient and not so easily sourced. No the seal should be one piece but it’ll need replacing regardless.
The headliner is there...it’s just black and not very well done
Bottom line it’s silly money and will more than likely sit
Bpt70gt Avatar
Bpt70gt Brian T
The one item that was missing when I purchased my surrey top were the 2 Escutcheon plates (#611668) located on the top rim of the backlight frame where the bolts go thru to hold the top mid roof section on. I couldn't find a source for them so I prototyped one on a 3D printer to make sure it would fit, then made them from steel. They work good, I painted them white because my headliner is white.
TR250 Surrey top eschustion plate.JPG    32.2 KB
gozto11 Avatar
they look good!
fyi, they're available thru revingtonTR in stainless, but not cheap...well 25 a pop. actually i think TRF lists them, but they're like $40
Bpt70gt Avatar
Bpt70gt Brian T
You're right Todd. I did see the ones TRF had but at $25 each, I couldn't see spending $50 plus shipping for a couple pieces of stamped sheet metal. I should have checked to see if Revington had them but still at their price and shipping it would be in the same $50 range. So I spent an afternoon in the work shop and had fun doing them. Instead of having ones made from 20 gage sheet metal, I made mine from 11 gage stock. These little plates were the last two things I needed to finish off my surrey top. It still worked without them but it looks nice and finished with these installed.
Edited 1 time(s). Last edit at 2017-12-07 09:59 AM by Bpt70gt.
dherr2 Avatar
dherr2 David Herr
Adamstown, MD, USA   USA
I might be persuaded to sell my Surrey top from my TR4A. I have enjoyed it for the last 17 years but have been considering selling the car and may be willing to sell the surrey top separately. It is an original aluminum back piece, original glass, TRF rear glass seals and a TRF surrey top frame and canvas top. The top is painted the same color as my car (green). You can see some pictures at the bottom of TR4A
I would want $3,500 for it plus any shipping costs
tirnipgreen Avatar
Ellijay, GA, USA   USA
1963 Triumph TR4 "YIN"
1965 Triumph TR4 "YANG"
Hey...Just curious, do you have the center hardtop panel for the Surrey...? Maybe that is the part that you say is painted green. If it is included, is the headliner in good condition...? Thanks, Ryals
dherr2 Avatar
dherr2 David Herr
No, when I bought it, it had the aluminum center panel, but it was too rough to restore it, so I sold it off years ago and just used the center "surrey" convertible top when it was needed. 99% of the time, the car is driven with the top off. I will need to go to my neighbor's house to get some pictures as the car is currently stored for the winter, but here is a small one below.
carpecursusII Drew H
Oklahoma City, OK, USA   USA
Can anyone provide some details about the mounting of the backllight to the car, I am looking at the area around the stud closest to the B post. How was this stud fitted??
gozto11 Avatar
Should be a nut welded to the underside “dog leg” piece. Under the aluminum cap. It has to be removed. If there is no hole it’s probably a replacement piece or you’re working with a TR6
Bpt70gt Avatar
Bpt70gt Brian T
Todd is correct. My TR250 has a threaded hole and there is a stud that you thread into that nut. The stud then comes up through the back light frame and then put a nut and washer on. The hole is under the cap as Todd mentioned.
So, then there is a stud at the B post then no attachment until the stud at the back corner. I am looking at a picture that appears to have a mount point between those two points.
Bpt70gt Avatar
Bpt70gt Brian T
If I recall, there are a total of 9 attachment points. Yes, there is a mount point between the B post and the corner.
gozto11 Avatar
On a TR4, the dogleg is "wider" all the way around the bend. beginning w the TR4A, that section narrowed to make room for the bigger convertible top frame. On a 4A/250/5/6, that stud closest to the B-post is removed. I snapped it off, but I think it may be threaded so you may be able to back it out.
LGMTR6 Avatar
LGMTR6 Larry Miceli
Mount Dora, FL, USA   USA
1952 MG TD
1954 MG TF 1500
1958 Triumph TR3A
1967 MG MGB GT    & more
Pictures would be a big help!
Larry Miceli
Mount Dora, Florida
52 MG TD (restored)
54 MG TF 1500 (project)
56 Triumph TR3 (project)
67 MGB GT (restored)
68 MGC GT (nice driver)
68 Triumph TR 250 (nice driver)
71 Triumph Stag (driver)
73 Triumph Stag (project)
74 Triumph TR6 (restored)
I've just never really figured out the "sell one when you get another" part of it all...
1966 Triumph TR4A
