TR5 & TR250 Forum
Water Heater valve
Bpt70gt Avatar
Bpt70gt Brian T
Westmoreland, NH, USA   USA
OOPS!! Moss lists one for $12.29. Just the straight extension type. Cheap enough.
Richmond TR250 Avatar
Richmond TR250 Paul Barlow
Richmond, BC, Canada   CAN
I saw that. I will go that root if all else fails. Monday or Tuesday will be the test as I am away until then
Desert TR Avatar
Desert TR Gold Member Jim P
Albuquerque, NM, USA   USA
I may have spoken too soon. It appears the TR4A use a 45 degree where the six cylinder use a straight connector. My point stays the same, its a basic plumbing fitting, not a specialty part. You can probably get on at your local plumbing supply for a couple bucks.
Jim
004 (2).JPG    48.3 KB
FWIW, TRF also has the extension, might be a little cheaper than shipping from the UK. Not a standard plumbing part, your local store would only have a female-to-female coupling plus a short nipple (male-to-male). Which would still work, of course.
Edited 1 time(s). Last edit at 2017-05-07 11:48 AM by TR3driver.
Well I finally got the extension out with a little help of WD40 soaking for 4 days. However I cannot get the broken piece out so I have a new one to arrive tomorrow. Any suggestions on what to put on the water heater valve thread so they don't get frozen again incase of a leak? Or is it the same process again.
Thanks again for all the assistance.
TR250Guy Avatar
TR250Guy Tim Moore
Dayton, OH, USA   USA
Just go to your local FLAPS and get a product called Anti seize.
1968 TR250 "TRminator"
Owned since 1980
I have some of that. Anything else for aluminum to steel?
Bpt70gt Avatar
Bpt70gt Brian T
Any one of the "anti-seize" or "never seize" products will work well. Glad you got the extension off. Now fiddle with getting the broken piece out of the old one. For two reasons, one so you will have a spare and two so you can have the experience of removing broken pieces from parts. Back in my working days, where I worked I could have put the steel piece in a vat of acid and the aluminum part would dissolve out in about 30 minutes. Ending up with a nice very clean steel part.
I do have some anti seize so i will use that and work on removing the broken piece when i have nothing to do. Ha ha. It will sit in the 'To Do' box. Again thanks for hte help.
For tapered threads like that, my preference is teflon pipe dope. It will help seal the joint with less torque as well as making it easier to remove next time. Pick it up at any hardware store, etc.
Eg, http://www.homedepot.com/p/RectorSeal-T-Plus-2-4-oz-Teflon-Pipe-Thread-Sealant-23631/100201204
Good Idea.
1961 Triumph TR3A
