TR5 & TR250 Forum
Tr 250 will not start
Mel tr250 Melvin W
Oakley, CA, USA   USA
Car was running fine set for a month will not start no spark i replace coil still no spark check volts to coil it ok
Brian Oklahoma Brian Plotkin
Edmond, 73012, USA   USA
1968 Triumph TR250 "Kevin"
ok. We need a little more information. Is the starter turning over?
Mel tr250 Melvin W
Oakley, CA, USA   USA
yes it turns over
Next question - when you turn the key does your ignition light come on (it should)? If it doesn't its likely you alternator or regulator are not functioning correctly. If it is coming on then you may have a problem with your replacement coil. Note: I'm assuming the distributor is fine.
Mel tr250 Melvin W
Oakley, CA, USA   USA
The ignition light come on when the key is on just got the new coil from trf
wyatt Avatar
wyatt Silver Member Wyatt W
penguin point, drift ice, Antarctica   ATA
points
If you are running points - seems like a likely culprit. Assuming this is an electrical problem - not a fuel problem - Its either the coil, the distributor or the wire between them. If it was past the distributor you would still have 5 plugs firing.
If you have electronic ignition those tend to go bad fairly frequently as well.
Points would be my first suspect, but rather than just looking at them, try a simple test. Connect a test light or voltmeter (DMM on 20vdc range) from the point terminal on the coil to ground. Turn the engine until the points are closed (one easy way is to put it in 4th gear and roll the car a bit). Turn the key on, check that the light is off or the meter reads 0v. Then turn until the points are open and check again. Should be light on, roughly 12v on meter.
This checks not only the points themselves (which rarely fail), but the wiring to them and the coil (which is a much more common problem area). (Also detects the common mistake of putting the top hat insulator at the points under the wires instead of over them.)
If that looks good, I would next check for spark right at the top of the coil (rather than at a plug wire). If you get spark there, you're probably looking at a bad rotor or coil wire.
If still nothing, I would probably try changing the condenser next.
Mel tr250 Melvin W
Oakley, CA, USA   USA
I just replace the points with a pertronix ignitor and coil starts right up Thank guys.
TuRtle5 Avatar
TuRtle5 Kevin Kelly
Absecon, NJ, USA   USA
1959 Triumph TR3A "Drandulet"
1968 Triumph TR250    & more
Hi Mel- best to keep the points and any parts you removed in your on board spares kit.
Mel tr250 Melvin W
Oakley, CA, USA   USA
Will do Thanks
IMG_0862.jpg    49.3 KB
