TR5 & TR250 Forum
Vacuum control valve
peerlessgt Avatar
peerlessgt paul milsom
leigh on sea, essex, UK   GBR
Yep, I've worked on this stuff fo r yonks, quite honestly, take ALL the vacuum stuff off and run without it. just use the centrifugal advance, and that's it. I fine tune my TR3 setup by reducing the amount of advanve with sleeves over the weight stops. prob was , set for good idle, too advanced on fast running, set for good fast way too retarded on idle, so limit the original advance from 11 degrees to abou 8 fabulous. just dump all the emissions junk. run without it.
peerlessgt Avatar
Yep, I've worked on this stuff for yonks, quite honestly, take ALL the vacuum stuff off and run without it. just use the centrifugal advance, and that's it. I fine tune my TR3 setup by reducing the amount of advanve with sleeves over the weight stops. prob was , set for good idle, too advanced on fast running, set for good fast way too retarded on idle, so limit the original advance from 11 degrees to abou 8 fabulous. just dump all the emissions junk. run without it.
Bpt70gt Avatar
Bpt70gt Brian T
Westmoreland, NH, USA   USA
Paul, That's what most folks have done, just remove them. But, I've sent a few of these vacuum valves out to owners that just plain want to keep the functionality as it was originally. I've got one on my TR and I have had no issues, no overheating etc., Sure, it was an attempt at meeting the USA emission standards at the time and by today's standards it was pretty crude.
oldjohnny Silver Member Johnny H
Macon, GA, USA   USA
Brian,
I have enjoyed following your engineering and design process on this valve. Since I am currently on the hunt for a TR250, I am interested in the outcome of the testing.
Your other projects are very interesting too.
Bpt70gt Avatar
Bpt70gt Brian T
Thanks Johnny, Thanks for the encouragement. I do like to create parts that seem to me to be overly expensive or are no longer available or in the case of the vacuum valve, you most likely have to find a used one and then hope that the 49 yr. old valve still works. Got that one solved I think, I put roughly 2000 miles on mine this past summer, a couple other 250 owners and a GT6 owner have them and have had good luck so far. The hazard switch I'm working on is getting close to completion. I have other parts for my GT6 and TR250 on my list of parts to try to improve upon or make. The challenge keeps my old brain working.
Good luck in yours search for a TR250, Great style car.
Edited 1 time(s). Last edit at 2018-02-01 06:02 AM by Bpt70gt.
1974 Triumph Spitfire
