Stag, 2500 & 2000 Forum
Stag brake brake actuator switch
Dave1954 Dave Carpenter
Newport, Risca, UK   GBR
Hi could anyone tell me exactly what the brake actuator switch does on a stag ,as I'm having trouble with rear brakes. Much appreciated. Dave
The Pressure Differential Warning Actuator (PDWA) basically compares the pressure in the front brakes to the pressure in the rear brakes; by applying each to opposite ends of a piston (or shuttle). If the difference becomes high enough to move the shuttle off-center, it grounds the warning light circuit. There is a write-up in the ROM, section 70.00.03.
But even off-center, it does not block off any of the pipes. Normally, anyway. Could be a foreign object in there I guess.
1974 Triumph Spitfire MkIV
