Stag, 2500 & 2000 Forum
Ignition Switch wiring
Stuber1644 Ed K
Wilmington, DE, USA   USA
1973 Triumph Stag "Betsy"
Hello,
I have installed a new ignition switch on my 73 Stag, and now the starter engages 1 step before it should on the key. Can anyone send me the correct wiring for the switch, please?
Thanks and Happy New Year to all.
Ed
This is all I have, from the Repair Operations Manual. But my earlier cars are different, so I'm not certain it is correct. My suggestion is to use a DMM or continuity tester to "buzz out" the switch connections (with the key in each position) and see if they make sense. You wouldn't be the first to get sold the wrong switch!
PS, here's the complete diagram. After you click the thumbnail, click the magnifying glass for a larger version.
Edited 1 time(s). Last edit at 2016-12-28 03:32 PM by TR3driver.
1966 Triumph Spitfire MkII
