Stag, 2500 & 2000 Forum
Triumph 2000 in Eugene OR
NMNA, but if a Triumph lover doesn't take it, will probably be parted out or crushed.
It's much too rare and nice for such a fate.
https://grassrootsmotorsports.com/forum/201x-classifieds/triumph-2000-in-eugene-or-spitsix-swap-donor/124697/page1/
Triumph Racer Avatar
Triumph Racer Patrick N
south bend, IN., USA   USA
1962 Triumph TR4 "Big Red"
Kyle,(twomanytriumphs) should be all over this. It is practically in his backyard.
twomanytriumphs Avatar
Kelso, Washington, USA   USA
1965 Triumph TR4 "My Baby"
1977 MG MGB
Carter.... Your evil. Kyle.
So Kyle,does the wife know what you want for Christmas now?grinning smiley
1977 MG MGB
Yup! 2000 parts. I ordered them a month or so ago. Ended up with progressive wound uprated 1" lowering springs, a new stainless head pipe, a pinion seal, and a new to me flywheel. This is to swap a gt6 mk2 engine into the car. Then I'll install the 15" minilites and new booster and drive it! Kyle.
1977 MG MGB
I think this one is headed to Ohio like the last one that left oregon. Kyle
gozto11 Avatar
gozto11 Todd Bermudez
Cincinnati, Ohio, USA   USA
In reply to # 1424082 by twomanytriumphs I think this one is headed to Ohio like the last one that left oregon. Kyle
Almost getting to be a thing smiling smiley
Chandlergti Adam C
Findlay, Ohio, USA   USA
I bought it, and it arrived this morning. I've not owned a Triumph before but a string of Rabbits, Datsun Roadsters, Corvettes and Porsches make this something new and different. I really like the size and styling and hope to not make a hash of it!
gozto11 Avatar
In reply to # 1425768 by Chandlergti I bought it, and it arrived this morning. I've not owned a Triumph before but a string of Rabbits, Datsun Roadsters, Corvettes and Porsches make this something new and different. I really like the size and styling and hope to not make a hash of it!
I'm gonna say they're not the fastest things on the road, but the front seats recline all the way, they have rear heat channels, indicators on the b-post, stirrups er uh hand grips...all for 1967
tapkaJohnD Avatar
tapkaJohnD John Davies
Chandler,
WELL DONE!!! Very glad to hear you have taken this on.
Most everything said on the GRM board was correct, save for changing the front and back plates and the sump if you wanted to put a 2.5 in.
That is true for a 2L or a 2.5 from a saloon or TR5/6 to fit it into a "small chassis" Triumph, one Herald based, but not for the saloon.
And the saloon has a one piece gearbox, unlike said small chassied cars.
Triumph used the 2L/2.5L saloons for rallying, and Paul Newman for racing. Long thread here about his, "Le Taxi": http://clubtriumph.eu/cgi-bin/forum10/Blah.pl?m-1202395099/s-90/
As Carter said, a 2.5L can make a difference to a car heavier than a Herald, but as it stands it a great motor. Often discussed on the above UK message board: http://club.triumph.org.uk/cgi-bin/forum10/Blah.pl/Blah.pl?b-2000/ and it has it's own Register where experts live: http://triumph2000register.co.uk/
Good luck!
1977 MG MGB
Slow? Mine will cruise at 80 and be plenty comfortable. I enjoy driving mine when I can. I'm in the process of swapping a later 2.0 into mine. But lack of carbs will stop me for a bit, but only to finish the gt6. Going to put fresh antifreeze back in it and put a new heater control valve on it and drive it. Kyle
gozto11 Avatar
In reply to # 1425952 by twomanytriumphs Slow? Mine will cruise at 80 and be plenty comfortable. I enjoy driving mine when I can. I'm in the process of swapping a later 2.0 into mine. But lack of carbs will stop me for a bit, but only to finish the gt6. Going to put fresh antifreeze back in it and put a new heater control valve on it and drive it. Kyle
Lack of carbs? I got carbs
And yes, they're slow. Yes, mine would go 80, but getting there may've taken longer than a 2.5. They called me captain slow for a reason. Of course I was the one with the giant cooler in the back seat
1977 MG MGB
I wonder if mine has to do with swapping the auto out? I've never taken the time to figure out what ratio the rear diff is. I think I'm going to put float bowl gaskets on the carbs I've got. I'd rather have adjustable jets, but run with what you've got, they have good shafts and are clean!
Kyle.
Did the 2000 come with Strombergs or SU's in the U.S. ?
gozto11 Avatar
In reply to # 1427924 by Tonyfixit Did the 2000 come with Strombergs or SU's in the U.S. ?
Zeniths
1979 Triumph Spitfire
