Stag, 2500 & 2000 Forum
A question about rad springs
sujitroy Avatar
sujitroy Sujit Roy
Cupertino, CA, USA   USA
The ride height of my Stag is bothering me. I swapped the front struts for some other set, off another donor car, as my originals developed a knocking sound which I eventually traced to a loose nut holding the shock down in the tube. For the front, from center of wheel to bottom of wheel arch I have 14.5 inches on one side and 15 inches on the other. For the rear I have 13 inches and 13.5 inches. I'm thinking of buying a set of 4 new progressive rated springs. I'd like to lower the car slight as well. Can any recommend what's a good height? It seems like the standard height should be 14.5 inches. I have 14 inch wire wheel with 185/70x14 tires. Even the side witht the13 inch distance seems to high.
I've been driving the car for some miles, but the front hasn't settled down any further
Sujit Roy
1980 Triumph TR7 Drophead
