Stag, 2500 & 2000 Forum
Stag oil ump
sagreenwoo Stuart Greenwood
San Diego, CA, USA   USA
When I rebuilt my engine I fitted a County oil pump
I have done 2000 miles since the install
Three weeks ago I was out on a run and the oil pressure started to drop and eventually went to zero at idle.
when I removed the oil pump I found that the steel bush that the relief valve slides in had come adrift from the housing
This was because the bush had not been staked in place
When this bush comes out of the housing it is jus like the relief valve being fully open
If you purchase a new oil ump ( County is the only option I'm aware of) before you fit it check that the bush is staked in place and, while you are at it, check all the clearances as per the ROM
Stuart
troppojohn Silver Member John Peers
Tinonee, N.S.W, Australia   AUS
Hi Mate I have a 77 Stag and it normally runs about 25 PSI above 2500 RPM when warm and can drop to 10 to 12 psi at idle, Just woundering what your normal oil pressure was before the pump failed.
1979 Triumph TR7 Drophead
