Herald & Vitesse Forum
Inner Ball Joint assembly needed for Triumph Herald
OZUSA60 Avatar
OZUSA60 Silver Member Carl Grady
Ridgewood, NJ, USA   USA
need to replace Track Rod & Inner Ball Joint assembly needed for Triumph Herald.. any recommendations appreciated
Carl
You know that theses are the same as on a Spitfire?
Was your one damaged? Wear is normally adjusted with shims.
quikrx Ralph Hansen
Antioch, IL, USA   USA
1962 Triumph Herald 1200
1987 Mazda RX-7 "Mistress"
Herald and Spit track rods are not the same, Herald is longer and has a needed bend in it - I do have an few extras
sorry, I was referring to the previous post
Edited 1 time(s). Last edit at 2017-10-04 01:03 PM by quikrx.
OZUSA60 Avatar
thank you ...I would be interested to buy /trade ? Carl 973 903 5334
In reply to # 1489982 by quikrx Herald and Spit track rods are not the same, Herald is longer and has a needed bend in it - I do have an few extras
According to rimmers they are the same part #?
https://www.rimmerbros.co.uk/Item--i-129961R
quikrx Ralph Hansen
Tony,
have numerous Spit and Herald track rods (link between body and rear upright) and they are different - I saw that also a while back in Rimmers
1970 Triumph TR6
