Herald & Vitesse Forum
Herald front Floorpans
Rampaart P R
West Fargo, ND, USA   USA
Greetings everyone!
As I am constantly amazed at the amount of knowledge in this forum, I'm seeking advice on how to remove the front floor pans on my 65 Herald Convertible. Sadly they are rusted through and need to be replaced. Any advice would greatly appreciated!
v/r
P
quikrx Ralph Hansen
Antioch, IL, USA   USA
1962 Triumph Herald 1200
1987 Mazda RX-7 "Mistress"
I haven't started my frt pan replace yet but I highly recommend getting the new part before cutting anything up or out - I have a new frt pan from Rimmers I can send some pics to you so you have an idea - it's the stamped pan they sell, really nice looking piece
Ralph
Herald948 Avatar
Herald948 Andrew Mace
I'm with Ralph on this. Also, I'd give some thought to using just what you need of the new panel. It might be a bit more cutting, but it also might otherwise make for as good (and easier) repair. But it all depends on just how extensive your rust is, of course!
Rampaart P R
I do have a pair of the pressed pans from Rimmer Bros. I've seen videos of people cutting out the old ones but would like to know if there's a better way.
quikrx Ralph Hansen
better or not is impossible to tell - each project, each person doing the job is different - my personal opinion is to cut/use the new panels/floor pans as much as possible and try to remove the old along spot welded seams or areas that are not as visible - imho, to hide the repair as much as possible, and I'm not talking about "under the carpet"
I agree with Andrew, typically the side peices of the new panel is far more than you actually need. Plan what you NEED to remove, then decide how much of a lip on the sides you need to keep.
Pay attention to the base of the 'A' pillar, you may have to add some sheet metal there.
How good a welder are you?
You may find it easier to overlap and plug weld than attempt a butt joint and seam weld.
1968 Triumph GT6 MkI
