Herald & Vitesse Forum
Mystery clips
caddis Chip Addis
Wayne, Pennsylvania, USA   USA
Hi,
While I am waiting for parts to get my Herald started, I thought I would ask if anyone knows what the parts/clips are in the attached photo and where they might go on my Herald.
Chip
IMG_3607.JPG    73 KB
tapkaJohnD Avatar
tapkaJohnD John Davies
Complete guess, but are they trim clips, to retain the end of some door or window seal?
The flat, other end would screw to a panel and be hidden under a carpet, or surface trim.
quikrx Ralph Hansen
Antioch, Illinois, USA   USA
1962 Triumph Herald 1200
1987 Mazda RX-7 "Mistress"
is the round end a full circle split on one side? if so maybe a ground clip for a bullet connector? - did not see any of those on 2 Herald 1200's I pulled apart in the last couple of years though
Herald948 Avatar
Herald948 Andrew Mace
I think those are the end caps for the outer top header rail plastic finisher (which might or might not be on your car?).
EDIT: In this image, the piece is towards the bottom of the photo, a bit right of center.
Edited 1 time(s). Last edit at 2017-07-12 12:31 PM by Herald948.
caddis Chip Addis
Hmmm, I am not sure what the outer top header rail plastic finisher is, Andrew. Thank you again!
caddis Chip Addis
John,
What is a bullet connector?
Thanks!
caddis Chip Addis
Yes, Andrew, that appears to be them! Thank you as always for your insights!
tapkaJohnD Avatar
In reply to # 1470256 by caddis John,
Thanks!
That was Ralph, Chip, not me.
And I was right, even if I couldn't point you to the precise aplication.
A prophet in his own land etc. etc
JOhn
Herald948 Avatar
Here's what bullet connectors look like, along with a typical "grounding clip":
Edited 1 time(s). Last edit at 2017-07-13 10:20 AM by Herald948.
bullet-connector.JPG    1.7 KB
bullet-connector-crimp-on.JPG    4 KB
grounding-clip.JPG    3.6 KB
Andrewhurstca Avatar
Andrewhurstca Andrew Hurst
Port Williams, Nova Scotia, Canada   CAN
1961 Mini MkI "The Mini"
1965 Triumph Herald 1200 "The Herald"
End caps for the bead on the convertible top head rail...
IMG_0664.JPG    38.5 KB
