Herald & Vitesse Forum
Front vertical link oil or grease?
suzukigt Peter S
NOTTINGHAMSHIRE, England, UK   GBR
Hi, OK I bit the bullet and splashed out on a front vertical link!, so what's best in the Trunnion oil or grease?, cheers
Herald948 Avatar
Herald948 Andrew Mace
This "debate" is as old as Ford v. Chevy, and far older than silicone v. glycol-based brake fluid. winking smiley
The general wisdom is that, while greases are far better than they were in the early 1950s, when Standard-Triumph started using this trunnion setup, the 90wt gear oil is still the superior choice, in part because it tends to flow better and in part because any grit is more likely to settle out to the bottom of the trunnion rather than remain in suspension.
Go with the 90wt oil! grinning smiley
tapkaJohnD Avatar
tapkaJohnD John Davies
Which is why the threads have two slots.
Honestwelsh Colin H
Bridgend, Wales, UK   GBR
EP 90 gear oil
ng19delta Avatar
ng19delta Scott Roberts
Merchantville, NJ, USA   USA
OIL! NEVER GREASE! Sorry, but I always have to yell this: While grease is improved, etc., it actually accelerates the wear in the trunnion. The oil does not. Just make sure to keep an eye on it, and it will serve you well forever...
Scott
1980 Triumph TR8
