Vendor Market
New Electronic Distributor 123Ignition perfect timing every time
emadak Avatar
emadak Gold Member Ed 123Ignitionusa LLC
Columbia Station, OH, USA   USA
1969 MG MGC
See 123ignitionusa- Triumph page
123\GB-6-R-V for the replacement of most 6 cyl. CCW 'Lucas' distributors
The 123\GB-6-R-V replaces most 6 cyl. Lucas-distributors for engines in Great-British (hence 'GB') cars, where the distributorshaft is turning in a CCW direction.
The unit offers 16 different advance-curves, that can be selected via a little switch. This is a great feature for easy fine-tuning your engine!
It also offers :
- vacuum-advance
- automatic dwell
- spark balancing
- automatic power-cut after 1 second
- gearshift retard
- etc. etc.
Triumph-owners should check if they need a connection for a mechanical rev.counter, as a 123\GB does not offer this.
Austin-Healey-owners are also advised to verify fitting dimensions beforehand.
NEW NEW NEW : now also available with 1 degree / PSI boost-retard ! ( ask for : 123\GB-6-R-V-BOOST )
Also Available in a TUNE programmable version. Just connect it to your PC or Laptop.
Edited 2 time(s). Last edit at 2016-06-25 10:00 PM by emadak.
Member Services:
US Supplier of 123Ignitions, Pre-programmed\switched models, Programable PC models and "NEW" Wireless Bluetooth models for Apple or Android. Search (123\Tune+) For perfect timing.
the froggy Yvan Alleau
Corvallis, OR, USA   USA
Hi Ed,
do you have a version working for a 1968 gt6 mk-1 ?
Also, non of the video comparison work using google chrome or internet explorer.
thank you
Jediscuba Avatar
Jediscuba Steven Spandorf
Southampton, NY, USA   USA
1963 Triumph Spitfire "Pussycat"
Link to page says ... Page not found
emadak Avatar
1969 MG MGC
Steven
Thanks for drawing that to my attention. All fixed!
Member Services:
1972 Triumph Spitfire
