Vendor Market
New Spitfire and any alternator B L I N G offerings!
kirks-auto Platinum Member Robert Kirk
Davenport, Iowa, USA   USA
Freshly commissioned and exclusively from Kirks!
Heat shield $25
Alt bracket $17
plus S&H
Regards,
Robert Kirk
kirkbrit@yahoo.com
Business phone 563 323 1017
Orders only please 800 547 5747
cell, if you must, and I know where it is 563 940 1864
http://kirks-auto.com
Moss distributor UK importer
Beat or match any retail/delivered quote
Heat shield Leyland 1500 dual SUs.JPG    60.1 KB
Alt safety bracket most cars.jpg    42.9 KB
FWIW UKC8372SS from Moss UK cost £25 that's almost $43 FOB at the current exchange rate
The alternator bracket is also a USA exclusive.
Regards,
Robert Kirk
kirkbrit@yahoo.com
Edited 1 time(s). Last edit at 2015-10-11 04:36 AM by kirks-auto.
Triumph7 Avatar
Triumph7 Paul Copeland
Notts/Derby Border, UK   GBR
Well done Robert. Nice piece of work!!!
MkIII D Avatar
MkIII D Mark Dineen
Hamilton, Ontario, Canada   CAN
Robert, could you drill the holes in the heat shield to fit 1 1/4 HS2's?
In reply to # 1242977 by MkIII D Robert, could you drill the holes in the heat shield to fit 1 1/4 HS2's?
That could be doable. Sorry for the tardy response, just read it. Email is best, PM works well too.
Regards,
Robert Kirk
kirkbrit@yahoo.com
jefferygt jeffery Ee
vantucky, wa, USA   USA
I would be interested in one for dual hs2 carbs intake as well.
Looks nice!
All you have to do is email me...
Regards,
Robert Kirk
kirkbrit@yahoo.com
Dave Braun Avatar
Webster, Minnesota, USA   USA
1952 MG TD "Tommy"
1970 MG MGB "Maggie"
1974 Triumph Spitfire 1500 "Sammy"
I have Robert's heat shield. It is a work of shiny art! With the European exhaust manifold, I elected to put a slight joggle in mine to keep it blocking the radiant heat, not conducting it! I used a bench brake, and very carefully bend in the joggle prior to removing his protective layer. The stainless steel bends with difficulty, it should hold the new shape with no problems!
Member Services:
dbraun99 LLC currently is unable to support Carburetor Bench Services on SU Carburetors due to heavy commitments to the Aviation side of the business. Thank you.
Laser film peeled from heat shield.JPG    36.5 KB
Using Bench Brake to put bends in Kirks Auto heat shield (3).JPG    37 KB
Heat Shield and Carburetors installed (1).JPG    43.9 KB
knottysticks Avatar
knottysticks Gary G
Regina, sask, Canada   CAN
Maybe a heat shield + alt for TR4's - [H6 carbs] hint hint ...
1962 TR4
The alternator belt guard fits any UK vehicle/Lucas alternator.
Regards,
Robert Kirk
kirkbrit@yahoo.com
In reply to # 1312435 by Dave Braun I have Robert's heat shield. It is a work of shiny art! With the European exhaust manifold, I elected to put a slight joggle in mine to keep it blocking the radiant heat, not conducting it! I used a bench brake, and very carefully bend in the joggle prior to removing his protective layer. The stainless steel bends with difficulty, it should hold the new shape with no problems!
Dave,
If I knew the angles I'd do it on a proper metal brake on all of them. Can you help?
Regards,
Robert Kirk
kirkbrit@yahoo.com
Smoothbrain Avatar
Smoothbrain Silver Member Thomas Nelson
Bettendorf, Iowa, USA   USA
Robert,
Will you have a display at Brit Auto show in LeClaire, 6 August?
Tom
Thomas Nelson
Bettendorf, IA
1970 Spitfire Mk III
The Village prohibits me from vending their. sad smiley Afraid of depriving taxpaying MG Midget retailers of revenue. eye rolling smiley
Regards,
Robert Kirk
kirkbrit@yahoo.com
