Clutch Fork Tapered Pin - Safety Wire?
AllanJ71MGB Avatar
AllanJ71MGB Allan Johnson
Princeton, NJ, USA   USA
1971 MG MGB "Batmobile"
1971 Triumph TR6
Thanks Randall. Definitely not running a convertible at -30..... or even -20.
I'll let you all know how I make out. Going to order the parts tonight.
Thanks!
-Allan
Brett E Brett Evans
Columbus, OH, USA   USA
If you do remove the gearbox it would be a good time to change the propshaft u-joints as removal of the shaft is so much easier with it out.
AllanJ71MGB Avatar
1971 Triumph TR6
Good idea Brett. Thanks! Question for all of you. Moss has an aftermarket as well as Hardy-Spicer/GKM. Anyone have any experience / preference?
-Allan
stage3 Avatar
stage3 Christian P
Saarbr├╝cken, Saarland, Germany   DEU
Hi Allan
I have used Hardy-Spicer/GKN UJs in several vehicles and never made a bad experience with them. Certainly better than the unbranded ones some companies sell.
Christian
Brett E Brett Evans
TRF has a kit that includes both u-joits (Hardy-Spicer / GKN) and all new hardware to refit the shaft.
AllanJ71MGB Avatar
1971 Triumph TR6
Thanks Brett. Wish I had seen this a little sooner. I ordered the parts from Moss yesterday and they were more pricey. I ordered pretty much everything I need except the tranny tunnel. The budget for the car is about exhausted.....
AllanJ71MGB Avatar
1971 Triumph TR6
Hi Everyone,
I am reaching out again... I just want to make sure I have my diagnosis right before I pull the transmission out. I have been driving the car a good bit the last week. I took it for a 60 mile drive to and from my folks place last night.
At times the car would go into first with no issue at full stop. Most other times it was a total bear to get into first and in some cases I had to time the traffic lights to turn the car off, drop it into 1st clutch in, and restart the to get going in first. Others times I could get it into second and roll the car enough forward to get it into 1st. Reverse grinds slightly so I have been turning the car off and dropping into reverse and restarting.
The car shifts fine when moving. No grinding. It is a wonderful ride 2-4 +OD.
Is this all symptomatic of the clutch fork pin? It just seems so erratic. Is there anything else I should look at?
Also, my speedo died again (It was broken when I got the car). I had a brand new angle drive and cable. The odometer did not work but the speedo part did and then it failed yesterday about a mile into the trip (been working all week). I used the washer in the angle drive like I was supposed to. Could it be the speedometer causing the failure? Is 3000RPM @60mph in 4th+OD normal? Seems high to me. My MGB is lower if I remember correctly in 4th+OD (Haven't driven it in a bit).
And my tachometer is REALLY noisy in a cyclical way. Anyone have any experience with that?
Thanks!
-Allan
Your clutch problems could certainly be something other than taper pin. The original setup is fairly marginal anyway, so anything that reduces travel at the TOB can cause problems.
One of the first things to check is the thrust washers in the engine. For reasons I've never understood, the TR6 only uses a half washer, and it is prone to rapid wear. Any wear can allow the crankshaft to float back and forth, which can push the clutch slave piston back into the cylinder and cause low travel next time. It's wise to check the wear periodically, since if it gets bad enough, the washer can fall out into the crankcase and allow the crankshaft to contact the block (next time you use the clutch), causing substantial damage to both.
Another common problem is wear at the pivot between the clutch pedal and the MC pushrod. That joint needs a drop of oil once in awhile, but frequently gets overlooked. The pin is easy to replace, but the holes wear too. On the Stag, I was able to make a temporary repair by reaming the holes slightly oversize (more nearly round) and using a hardened metric bolt for the pin. But of course the right solution is to remove the parts and have them welded, so the holes can be reamed back to original size.
Less common problems include weakening of the plastic line from the clutch MC to slave (improved "SS braid" lines are available from several sources, including TSi http://www.tsimportedautomotive.com/tr250_tr6.html )
There should be springs inside both the MC and slave. MC springs sometimes break; the slave spring is sometimes missing entirely.
Make sure the clutch pedal returns all the way. It should pull (lightly) against the MC pushrod.
Some people have even gone as far as to fit the clutch MC from a 69 TR6, which has a slightly larger bore. The larger bore means a bit more force at the clutch pedal; but also increases the travel at the slave. Sometimes it's enough to overcome the other problems.
Could well be the speedo causing the angle drive to fail. There is a bushing in there that dries out over the decades. If it turns a bit stiff cold, then the bushing material gets hot and binds worse after driving a few miles.
3000 rpm @ 60 mph sounds like your OD is not working. What do you get with the OD disengaged?
Obviously, could be either tach reading high, or speedo reading low.
AllanJ71MGB Avatar
1971 Triumph TR6
Thanks for the reply Randall,
I guess I am a little confused about how all this works..... hoping you can explain.....how does the TOB affect the ability of the transmission to drop into gear? If it is not pressing fully, my brain is suggesting the gears just grind if I am at stop and go from Neutral to 1st? Again, I can force it into second (and I mean FORCE) with no grinding, get it rolling and then FORCE it into 1st. Whereas without it rolling, full clutch, I cannot physically force it into first but it doesn't grind either. The only grinding is reverse. I am assuming it is because it is non-synchromesh.
Also, could I be burning through my synchros driving this car? (drove it today to work - gorgeous out). Is the lack of full clutch being compensated by the synchros?
How would I check the thrust washers in the engine? I am planning on just pulling the transmission (I don't have a hoist). Can I just see if there is any horizontal float in the crank by pulling and pushing on the flywheel when the transmission is out? Or am I not going to be able to manage that? (with any degree of detection?) Or is this check something that needs to have the engine pulled? Or just the oil pan?
I've got all new clutch hydraulics. They seem to be working correctly with adequate travel and the pedal returns to its starting point. I guess it is possible I need to bleed it more but it is fine in gears 2-4 (not reverse).
The OD was definitely working with it off it was around 3600 for 60 mph. It seems really fast by the engine pitch.... My MGB without OD was 3K and with is around 2400 @60mph. The TR6 speedo had just broken so I installed a GPS speedometer on my smartphone called DigiHUD (Android). Kind off cool. It also has a HUD mode which works like an aircraft HUD where you can lay it on your dash and it mirrors the display so that when it reflects off the windscreen and you can see your speed correctly reflected in the windscreen. I've used it in my Toyota Camry and it's speedometer seemed pretty on target with the App. Also, it seemed pretty accurate with the traffic speed on the interstate: At 60mph, I was falling behind and at 70mph I was keeping pace with traffic.
Did the TR6 have a different gearbox ratio set available or a different rear differential that could be changing the final drive ratio and making it high? I looked online but didn't find anything.
I've never really dealt with a slipping clutch.... while it could be slipping during acceleration it seems proportional in all gears and 'launch' seems normal to me. I tend to think your suggestion of the tachometer being off is an option. I know the tires are correct. I think I am going to rig up a tach/dwell meter I have while driving so that I can see if it is off. I am not sure how off it could be though.... the engine sounds really fast at idle and the tach is reading about 2K.
Allan
In reply to # 1465470 by AllanJ71MGB Thanks for the reply Randall,
Perhaps I have assumed too much, Allen. To shift to reverse, you should first depress the clutch, then partially select one of the forward gears, then shift into reverse. That uses the synchromesh of the forward gear to stop the gearbox input shaft from spinning, so you can engage reverse without grinding. If it still grinds, even a little, that is a fairly certain sign that the engine is still trying to turn the input shaft. Usually, it means the clutch is not fully disengaged (but could be other things).
Quote: Also, could I be burning through my synchros driving this car? (drove it today to work - gorgeous out). Is the lack of full clutch being compensated by the synchros?
Yes, that is exactly what I think is happening and it will wear the synchros out eventually. Then you'll start getting grinding always, instead of just in reverse. A healthy synchro ring will keep it from grinding, at the expense of not letting the gear teeth touch until they are synchronized. (They are also sometimes known as 'baulk' or 'blocker' rings for just that reason.)
Quote: How would I check the thrust washers in the engine? I am planning on just pulling the transmission (I don't have a hoist). Can I just see if there is any horizontal float in the crank by pulling and pushing on the flywheel when the transmission is out? Or am I not going to be able to manage that? (with any degree of detection?) Or is this check something that needs to have the engine pulled? Or just the oil pan?
IMO it is best to have a dial indicator and magnetic mount. They aren't terribly expensive (under $30 for a cheap import last time I looked). There is a very small range allowed; something like .005" minimum and .007" maximum (please check the book, I may not have the numbers right). A little bit more probably won't hurt anything, but even .010" is really tough to judge by eye.
With the engine off; step on the clutch to move the crankshaft all the way forward. Setup the dial indicator so it is bearing on the end of the crankshaft, axis in line with the crankshaft and note the reading. Then lever the pulley (and crankshaft) to the rear. The change in reading is the end float. IIRC there is a diagram in the workshop manual. Although they show the engine out of the car for clarity, it can be done in the car.
Quote: Did the TR6 have a different gearbox ratio set available or a different rear differential that could be changing the final drive ratio and making it high? I looked online but didn't find anything.
Yes, definitely. I don't think the factory listed them as an option for the TR6, but the optional 4.1 gears from a TR3-4 will fit the TR6 diff; as will the 4.30 gears from some other Triumphs. They are often used by racers, in combination with other modifications causing the engine to reach peak power at higher rpm. There is even a 4.56 set that will fit (but I can't imagine where it would be useful).
For example, my current TR3 came to me with a 4.1 axle. Since it didn't have factory overdrive, and it didn't have the right speedo head for a 4.1 axle; I'm pretty sure a previous owner changed it.
Again, strange things can happen. The tach is the same movement as the speedo (without the mechanisms for trip and odometer). I put a used speedo from another TR3 onto mine, and it would bounce between 90 and 120 mph while I was actually only doing about 75.
FWIW, here's a video I just found on YouTube, showing how the synchro/blocker rings work. The other details aren't exactly identical to the TR gearbox, but are very close. It's that last step, where the ring has to turn back a bit to allow the shift ring to slide over it, that makes it hard to shift if the clutch (or pilot bearing) is dragging.
AllanJ71MGB Avatar
1971 Triumph TR6
Hi Everyone,
Sorry for the drop off the planet..... Life has gotten interesting... Thank you all for your time throughout this journey. Randall, thank you for your last post.
It was the perfect Roadster day today here in the Northeast.... and I with 2 LBCs could not drive either. The 71 MGB is in storage because I have the TR6 in the single garage. The TR6 is in limbo. So, I am trying to fix the latter.
Next week I will have 3 weeks to get back to my transmission issue. I have a full gasket set and seals, a new clutch kit, fork, shaft, bushings. The OD transmission is ready to come out except for the bell housing and starter (the seats, tunnel, wiring, and console are out). My friend is coming Sunday to help me pull.
Wondering if I should invest in 4 new synchros to have on hand?
Also, any other parts I should invest in? I see thrust washers, mainshaft bushes and bearings.
My budget is getting tight. I went gung ho in the spring and the summer vacations and kid camps are hitting the wallet hard (plus I have a lot of expensive parts I have not installed yet). If you think I should get these additional items, weigh in. I can get them but I am just not experienced enough to figure out whether I should or what to get. Also, this 1971 TR6 has an overdrive. Not sure if that matters....
I did drive this car a good bit with the "tough to shift/start in 1st" issue which is why I am asking about the synchros. Wondering if I beat them up too much. If I do get them, how hard of a job is it to change them? I have the Haynes manual....
And where should I get them? TRF has them on sale for $12, Moss has a premium for $22 and $11 ones that they say they don't recommend. Wishbone has them for $25 (yes, read the reviews and I am hesitant to say the least), and VB for $10.
Thanks again,
-Allan
Edited 2 time(s). Last edit at 2017-07-31 07:03 PM by AllanJ71MGB.
I can't help you on where to buy them, but TRF is where I'll buy mine. They had some trouble back 20-30 years ago; AFAIK no one ever figured out just what the problem was (which dimension was wrong or whatever), but the rings they were selling then would not always work. But, I'm reasonably certain they have a new batch since then smiling smiley And almost all the other vendors were selling the same thing.
As far as stocking up; I would definitely wait until you have it apart and can check other components. Very likely, you'll need a new countershaft and it's associated bearings, but you won't know until you see the old one. Any other bearings with even a hint of roughness should be replaced. The constant bushes may or may not need replacing, have to measure them. Much the same goes for the OD.
It's been a long time since I cracked a TR6 Haynes, but ISTR it just says to take the gearbox to someone else. But there are some really good articles at
http://www.buckeyetriumphs.org/technical/Gearbox/GearboxDisassembly/gearboxdisassembly.htm
http://www.buckeyetriumphs.org/technical/AOD/AOD1/AOD1.htm
and
http://vintagetriumphregister.org/maintenance/
(scroll down to the "Greasy Hands" links)
Also lots of info in the factory workshop manual (tho it tends to rely heavily on special tools that are NLA)
https://drive.google.com/open?id=0B2H2NJt34OffZTJaeXJhWllGWnc
AllanJ71MGB Avatar
1971 Triumph TR6
Hi Randall,
Thanks for all of the thoughts and links. I was thinking to order the parts ahead so I had everything on hand and didn't have to wait for shipping delays. I really only have 3 weeks and then I am back to full time dad and work routine.
After reading through the links you sent I think I am over my head in terms of dis/reassembly. I have a really small garage and I don't have a hydraulic press or some of the tools needed to weld up brackets/pullers I saw on the Buckeye site. (I miss my welder!)
20 Years ago, a friend easily replaced the synchros in my MGB OD unit. I don't remember the steps involved but it didn't seem as complicated at this. I am nervous to say the least.
Thanks for all of your help. I will send an update on the fork as soon as I can (Sunday or Monday).
-Allan
AllanJ71MGB Avatar
1971 Triumph TR6
Hi everyone,
I pulled the transmission out today. As soon as I had it on the ground I inspected the clutch shaft for play (see video/photos). The shaft rotated more than the release fork and was loose. I cut the safety wire and it was a bit of a struggle to get the pin turning and out. The pin is definitely broken. (see photos).
https://goo.gl/photos/P9jWyMf1sjp56By7A
So, I have a number of questions at this point:
  1. Does the movement due to the broken pin in the video look sufficient to cause my shifting problems?
  2. I could not get the remainder of the pin out of the shaft and therefore could not get the fork off. The new fork is not like the original. It seems of lower quality and does not have the flat spot where I have seen others drill a 1/4" cross bolt. So my first question is should I find some way to recover the fork? I have tried to drill but it is really hard steel and I am not sure in the end after my efforts if the fork will be usable. Worth it? Or should I use the new one and attempt to cross drill even though it is rounded? Additionally, I read an article here that mentions drilling a hole opposite the pin threaded hole to drive out the pin remnants. Thoughts on that?
  3. There was a lot of oil in the bell housing and I am not sure where it is coming from. Is it possible it is from the rear main seal of the engine? Or is it more likely that it came out of the transmission input shaft/layshaft? I have a couple of photos in the album of both the bell housing and the bottom of the flywheel. There is a lot of oil residue on the oil pan as a whole and it is just tough to see where it originated. If it is from the rear main seal, can that seal be changed by pulling off the flywheel? Or does the engine back plate need to come off (and therefore the engine out of the car)? I can take additional pics if needed.
  4. My last question is how far do I need to tear the gearbox down to check on the synchros, countershaft, bearings, constant bushes, and the OD? After looking at the videos that Randall sent they show a number of home made extractors to pull the gearbox apart and I don't have the tools needed to make them. Just a bit concerned....
Thanks in advance for any thoughts/advice,
-Allan
1979 Triumph Spitfire 1500
