What did you do with your TR6 today?
Skye Avatar
Skye Webmaster Skye Nott
Vancouver, BC, Canada   CAN
1964 Vespa VNB 125
1966 MG MGB "The Bomber RIP"
1983 Suzuki MC GS750E "Kate"
1986 Merkur XR4Ti "The Rally Car"    & more
Did you repair or replace some worn out parts?
Add a new accessory?
Take it out for a drive on twisty back roads?
What did YOU do with your TR6 today?
Post your update below......
Webmaster, The Triumph Experience
Member Services:
Building the best online communities for auto enthusiasts
dicta dick Taylor
Skye --- My '73 had picked up a few rattles since installing the hard top a couple of years ago. Yesterday, I went over the whole car with a hand full of socket wrenches and tightened (almost) every bolt that fastens the tub to the frame, along with the dash support bracket bolts. Wow, what a difference. Some of them took several turns before becoming snug again. After a test drive, the car is now back to being sufficiently quiet without these distracting sounds! I hate squeaks, rattles and groans.
Dick
Skye Avatar
1964 Vespa VNB 125
Wow, a couple turns to snug!
I feel much better after I find things like that... I'm sure it made a huge difference
Skye
Member Services:
ed.h Ed Hollingsworth
Omaha, NE, USA   USA
Fooling around with carbs. well, one of them.
SDC10044.JPG    48 KB
Skye Avatar
1964 Vespa VNB 125
Whoa! You win the "before and after" prize!!
thumbs up smileys with beer thumbs up
Member Services:
Yesterday...
chastelese charles telese
allentown, USA   USA
1974 Triumph TR6 "My Crisis"
Purchased the 'Toy' in 2012. A survivor with 39,000 original miles. Last winter worked on the more pressing mechanical issues, the front suspension, tires, water pump, and exhaust system. This year, since the weather has not been cooperative n eastern PA, I am working on some cosmetic items. Refurbishing seat foam along with replacing the worn out seat belts, replacing visors, repainting the spoiler, and a few other minor items.
20120613 Toy.JPG    56.4 KB
TR6Ken Avatar
TR6Ken Ken U
Loomis, CA, USA   USA
Installed a spin on oil adaptor.
ng19delta Avatar
ng19delta Scott Roberts
Merchantville, NJ, USA   USA
Great day on the TR6 today- After a short meeting at work, I headed back home(I was otherwise off) and pulled my 42 Dodge WC-51 restoration project out of the garage, & worked on getting the inner rocker in! I got to use my "new" toy- a Hobart Handler 120 Mig Welder! I just picked it up, and was looking forward to the upgrade from the flux wire...
I had most everything ready to go, but had to jack the dash up a little, to pull the side back into place: With the floor out & the rocker replaced, and the inner rocker still out, it had settled. A bottle jack & some angle iron served to lift everything back into place!
Got it all in- just some finish up to do & I can start on the front footwell...
Scott
triumph74tr6 Avatar
triumph74tr6 Chad Jester
Tulsa, OK, USA   USA
1968 Triumph TR250 "Gene"
1971 Triumph GT6 MkIII "Ken"
My daughter took ME for a drive in the TR6.....first time ever. She took off like she'd be driving it for years....proud of her. Of course she has a Mini Cooper S with a 6 speed for a daily driver....she rakes it through the gears like Danica Patrick.
jdub jeff westbrook
astoria, NY, USA   USA
I covered up a hole! Well, last night. Not today. Please note the fine attention to detail and expert metal fabrication. Thank you.
Screen shot 2014-01-28 at 2.02.36 PM.png    414.8 KB
ng19delta Avatar
Did a bit of engine compartment disassembly... I do have a couple questions about the head on the engine: It is a correct CF engine...
Is this the correct head?
Scott
And what is this serial number? (219019)
Aaand so you can see how much space I have to work with when I can't move the Dodge WC out because of the weather...
1234 Stephen W
Brampton, ON, Canada   CAN
Carried out some sanding to my rag top frame and will prime and paint.Then my brand new Robbins top can be installed when the weather is warmer here in Toronto.
Steve
75/TR6
1234 Stephen W
In reply to # 933251 by Skye Did you repair or replace some worn out parts?
What did YOU do with your TR6 or TR250 today?
1234 Stephen W
Getting my rag top frame sand blasted and ready for paint as I want to get my new Robbins top on for spring .Cant wait.
image.jpg    33.3 KB
