Carb linkage photos
Triumphal Al Ramsay
Nanaimo, Canada   CAN
I have a 73 TR6 and had the motor apart for repairs. After putting it back together I am not sure the carb linkage is right. Anyone got some detailed pictures they could post? Thanks..Al
There's pictures in Haynes and in the Bentley in their "Fuel System" chapters...but here's a couple of photos in case you don't have either one.
The first is the pre 73. The next 2 are post 72 with the captive auxiliary return springs:
ZS carb..pre73 001.JPG    35.3 KB
ZS carb linkage (2).jpg    56.6 KB
ZS carb post 72.jpg    52.9 KB
Triumphal Al Ramsay
Nanaimo, Canada   CAN
Thanks that should help..I will look at the car later today...Al
Genoa Bay Eric Williamson
Genoa Bay, BC, Canada   CAN
Al,
I have a 73 if you need reference. I’m just down the road near Maple Bay.
And yes, the actuating rod is supposed to be bent.
Eric.
Triumphal Al Ramsay
Nanaimo, Canada   CAN
Eric
Thanks..I am taking it to Doug Unia tomorrow to check it out and will let you know..Al
Hotshoe Ken Brinkley
Portland, OR, USA   USA
Hello ,any photos of ratco weber linkage conversion ?
2ml2us2 Avatar
2ml2us2 Tom Brocke
Haymarket, VA, USA   USA
Away from my car at present. I can supply a Ratco linkage pic. If you are not concerned with maintaining originality, I would suggest switching to a Ratco linkage. It removes the ball and socket pivots; a major wear point in the stock linkage. It's best point, IMO, is to remove the play in the stock linkage for much more precise carb adjustment.
Thanks ,very excited to eliminate the ball and crank . Cheers Ken b
Triumphal Al Ramsay
Nanaimo, Canada   CAN
it would appear my problems have been solved with my latest round of adjustments. although i found the Ratco linkage idea interesting but expensive. if i have more issues i may look at it...Al
1974 Triumph Spitfire MkIV
