Brake booster?
NHinNC Avatar
NHinNC Larry C
Greensboro, NC, USA   USA
Thanks, Brian. I am not going to rebuild the booster. Trying to save $, and I do think it is OK. It is not too big of a task to pull it out if I need to later. I drained it and painted it, and replaced the vacuum hose grommet.
Purchased July 2015
Bpt70gt Avatar
Bpt70gt Brian T
Westmoreland, NH, USA   USA
I hear you Larry, I'm doing the same when I rebuild mine this spring. The booster still works fine so I'll just clean it up and do the "minor kit". I ended up purchasing some "filter foam" from Mcmaster. and cut the filter from that. Filter in the center. Still wonder why the kits don't come with the filter.
TR250 Brake minor kit.JPG    39.9 KB
1961 Triumph Herald
