KYB Front shocks # GSA272HD installation help, 74 TR6
jfmdigital John Martin
Graton, CA, USA   USA
I'm trying to install KYB front shocks # GSA272HD on a 74 TR6. I thought it was a simple bolt on. No such luck. For one thing, the stock bolt on the bottom does not fit the KYB shock, too big in diameter. How do I set up the top of the shock?
Who did you buy the shocks from ?
Graton, CA, USA   USA
I bought the shocks from British North West.
https://www.bpnorthwest.com/shock-absorber-gas-front-tr4a-tr6.html
From the picture, although you can't tell about the diameter of the sleeve bushing inset with the lower 'rubber' bushings it does look like it has the correct type top and bottom ends.
Sometimes you have either extent or compress the shocks during installation.
Maybe you can transfer the sleeve from the old to the new on the bottom.
Edited 1 time(s). Last edit at 2017-12-27 07:47 PM by poolboy.
rjc157 Avatar
rjc157 ralph c
pearl river, NY, USA   USA
Ken the top rubber mounts don't look right shouldn't they be oval like the washers
gozto11 Avatar
gozto11 Todd Bermudez
Cincinnati, OH, USA   USA
How about posting some pics of what you have?
So I gather the old shock is out and you’ve removed the 2 brackets from the bottom of the old shock?
Graton, CA, USA   USA
Yes. Old shocks are out. Here are some pics. I thought maybe a machine shop could bore out the KYB bolt hole so I can use the stock bolt.
shocks1.jpg    57.8 KB
shocks2.jpg    69.8 KB
gozto11 Avatar
Never seen one like that. Might wanna call Leighton
rjc157 Avatar
rjc157 ralph c
I would call them first something doesn't look right there are a pair now on EBAY that you can compare them to
gbtr6 Perry Rondou
Titletown, WI, USA   USA
Those should be a direct bolt on. Mine looked like that.
Perry
Graton, CA, USA   USA
Problem solved. I bought a set of front shock bottom brackets from TRF. The bolt from the package fits the KYB shocks perfectly! Shocks are installed, way better handling!
Reddragon Avatar
Reddragon Dale M
Chesapeake, VA, USA   USA
1974 Triumph TR6 "Tweety"
Perry
That begs the question, what was the difference between what you had and what you bought from TRF?
On the ones you had were the center hole enlarged for a bigger bolt?
Thanks Red
Graton, CA, USA   USA
When I removed the bracket bolt from the old Monroe shocks, I discovered it was a hair too big to fit in the KYB shocks. The bolt in the package of the TRF shock bottom brackets were a perfect fit.
1972 Triumph GT6 MkIII
