Lucas SSB103 battery isolator switch?
JFB Joseph Byrd
Dunn, NC, USA   USA
I feel embarrassed to ask, BUT, I want to remove the battery cutoff I had installed several decades back.
I have the switch body behind the console however I can not see how the knob can be removed.
before I chisel it off, anyone know what I am blind to?
(I don't have the 43mm hole as shown required. my hole is a snug fit to the knob's shaft)
Edited 1 time(s). Last edit at 2017-12-19 07:08 PM by JFB.
lucas ssb103.jpg    26.7 KB
A. Bradley Aaron Bradley
Erwin, TN, USA   USA
1975 Triumph TR6 "The TR"
Maybe there's a tiny hex screw in the knob or it's glued and/or pressed on. 'Sounds like you'll have to destroy it if that knob won't budge. I opted for the modern 'red plastic key' type cutoff.
motowfo Avatar
motowfo Richard Mathis
Kirkland, TN, USA   USA
A picture of your current setup may yield additional thoughts.
JFB Joseph Byrd
Dunn, NC, USA   USA
Good Ideal, sometimes the camera can find things I can't see.
its a cold rainy day in NC, I went out to take a serious of pics as I turned it 360, BUT the batteries died and only got a couple photos. I did take a flashlight and there is no set screw in the knob, nor a flat spot on the little bit of exposed shaft.
given I installed this couple or more decades, my gut seems to remember thinking "once this thing is installed it ain't coming back off".
BTW, what would have been in the console hole below the radio?
CUTOFF 002.jpg    35.6 KB
CUTOFF 001.jpg    25.2 KB
Will it unscrew ?
JFB Joseph Byrd
Dunn, NC, USA   USA
not by hand, by me. also, the car was stored outside for a couple decades so things did corrode and get moldy.
before I put a pipe wrench on it, I wish I could know
JFB Joseph Byrd
Dunn, NC, USA   USA
Ab ra ca da bra......
CUTOFF.jpg    22 KB
motowfo Avatar
Always hate to ask magicians to reveal their secrets... but... ???
JFB Joseph Byrd
Dunn, NC, USA   USA
I was hoping some one would ask
here is how I thought about this.
"If I could not remove the knob from the switch, then remove the switch from the knob."
Actually, a friend from another Marque forum asked the UK Triumph forum
CUTOFF 003.jpg    29 KB
motowfo Avatar
I will keep your secret, secret! smileys with beer
1972 Triumph GT6 MkIII
