Which speedometre cable?
SGOUD Avatar
SGOUD Serge Goudreau
Sherbrooke, Québec, Canada   CAN
I'm removing the two part speedometre cable on my 76 TR6 and will replace it with a single cable with an overdrive transmission to be installed during winter. Do I use a 69" or a 72" cable with the O/D trans; I already have a right angle adaptor that I could use.
What should I use?
Casey808 Avatar
Casey808 Casey S
Honolulu, HI, USA   USA
1969 Triumph TR6 "Adèle"
In reply to # 1503330 by SGOUD I'm removing the two part speedometre cable on my 76 TR6 and will replace it with a single cable with an overdrive transmission to be installed during winter. Do I use a 69" or a 72" cable with the O/D trans; I already have a right angle adaptor that I could use.
What should I use?
Bonjour Serge,
For OD you want the longer or longest cable and thread it over the transmission to come up thru the firewall, not under. Also make certain you insert the copper washer for the Angle Drive between the OD Driven Gear to prevent it from cracking in two pieces per the BL Technical Service Bulletin. winking smiley
Gardez-les sur la route! Chin-Chin! smileys with beer
Edited 1 time(s). Last edit at 2017-12-21 03:38 PM by Casey808.
Speedo Cable.jpg    55.6 KB
SGOUD Avatar
Merci Casey,
That's the answer I was waiting for. Very helpful.
Serge
In reply to # 1503711 by Casey808
What should I use?
Bonjour Serge,
For OD you want the longer or longest cable and thread it over the transmission to come up thru the firewall, not under. Also make certain you insert the copper washer for the Angle Drive before you thread it on the Driven Gear to prevent it from cracking in two pieces. winking smiley
Keep 'em on the road! Chin-Chin! smileys with beer
Casey808 Avatar
Casey808 Casey S
In reply to # 1503716 by SGOUD Merci Casey,
That's the answer I was waiting for. Very helpful. Serge
Toujours mon plaisir d'aider les autres avec des connaissances partagées. As your OD conversion progresses, please reach out for any head scratching solutions as we're all here to make sure you end up enjoying a fun drive.
Québec must be beautiful this time of year as I admire your city, great food and love the golf courses. thumbs up
Joyeuses fêtes et tout le meilleur de la bonne fortune dans la Nouvelle Année! smiling bouncing smiley
Edited 1 time(s). Last edit at 2017-12-21 03:57 PM by Casey808.
SGOUD Avatar
Casey,
Oui, très beau paysage ici présentement avec neige et -12°c.
Merci et joyeuses fêtes!
Serge
