Large washer found in door
gr8britt Avatar
gr8britt Andrew Blood
Grimsby, ON, Canada   CAN
Hi all,
I was gutting my passenger door to replace/refurbish any dodgy components and came across a large washer lying in the bottom of the door. I have checked online and all the parts drawings and cannot, for life of me, find where it belongs. It wasn't there when I started. It's the one leaning on the spanner (wrench).
Can anyone suggest where it lives?
Andy
2017-12-13 16.59.38.jpg    43.4 KB
Looks more like a distance piece (spacer) laying against your spanner (wrench)..winking smiley
gr8britt Avatar
Hey Ken,
Yeah it sure looks that way but no clue what it was doing in there!
In reply to # 1502637 by poolboy Looks more like a distance piece (spacer) laying against your spanner (wrench)..winking smiley
ng19delta Avatar
ng19delta Scott Roberts
Merchantville, NJ, USA   USA
I believe it is one of the distance washers for the window tracks. Besides that, I'd say put it back exactly where you found it... TR6s are VERY finely balanced cars, using the utmost of English precision workmanship to stabilize and laterally balance the vehicle. This washer was obviously a precision set balance augmenter- and as we all know, the removal of such an augmenter could negatively effect the vehicle! Without that weight in the proper place, the car could cut fast through a curve, have a hyperspace spin, and end up in another dimension- something none of us really want to experience (again)! Or not.
Scott
PS- pretty sure it is simply an extra spacer that got dropped during manufacture...
Reddragon Avatar
Reddragon Dale M
Chesapeake, VA, USA   USA
1974 Triumph TR6 "Tweety"
Andrew
Like Ken stated. it is a spacer. It probable came off the front or rear window track keepers at the top tightening points,
If you can slide your window a little front to back when fully raised than you need to replace it. Positioning will be dictated by how close or far the glass is to the the windshield frame.
Red
1963 Triumph Spitfire 4 MkI
