Fuel pump pressure
Fuel pump pressure
  This topic is about my 1976 Triumph TR6
alexwoof Avatar
alexwoof Roger Bean
marquette, MI, USA   USA
Good morning...tested my fuel pump this morning finally...I was lucky to get 2 lbs upon cold cranking..kinda low isn't it...enough to make my car run rough at higher speeds?...thanks
Perdido Avatar
Tuscaloosa, AL, USA   USA
Roger,
What carbs do you have? The SUs on my Bugeye, MGB, and TR4a require low pressure, 3-4lbs. I’ve never checked the pressure of a mechanical fuel pump, only electric.
Rut
titanic Berry P
Albany, OR, USA   USA
The Haynes manual lists the pressure as 1.5-2.5 psi.
Berry
alexwoof Avatar
alexwoof Roger Bean
Perfect...thanks to all...merry Christmas
Mechanicsville, VA, USA   USA
My new fuel pump from Moss puts out 1.75psi.
1979 Triumph 1500 TC
