Convertible top frame to door window gaps.....
Charleston, SC, USA   USA
I'm in the early stages of installing my new top, webbing, velcro and channels/weather strips. I rolled my windows up and the top frame follows the drivers side window until the front rail. The passenger side window doesn't match very well at all. The top frame bows on the back side rails and is straight on the front side rails causing the triangular gap. Any ideas? I haven't moved the top frame around where it mounts in the car yet but was wondering if this is normal. I would think the front side rail should bow like the rear side rail in order the follow the shape of the door glass.
20171201_140401.jpg    43.1 KB
20171201_140401-1.jpg    44.7 KB
20171201_140453.jpg    40.4 KB
20171201_140453-1.jpg    42.8 KB
mhbva Avatar
mhbva Marc Botzin
Lorton, VA, USA   USA
1976 Triumph TR6 "Monty"
The front rails on my car are straight and the rears are slightly curved, although the rears in your pictures look to be a bit more curved than mine. They do not exactly conform to the shape of the glass, but the variance is largely covered by the flaps or reflective material on the top if it has not shrunk as they tend to do over time.
Thanks for the info.
I was wondering if mine were not correct. I don't have the A pillar weatherstripping on yet either but I'm hoping that will help with the triangular gaps at the front of both window glasses. I'm going to install the webbing after work and lay the top out on the frame to see how it looks on the sides where the Velcro is installed as well as the reflective strips. Thanks again!!
mhbva Avatar
mhbva Marc Botzin
Lorton, VA, USA   USA
My suggestion is to leave the weatherstripping longer than the A pillar to fill what may be a small gap at the corner and trim it as needed. There is a small gap at the front corner and along the top of the glass on my car that do not cause a problem, but the top and trimming was installed 30 years ago and has shrunk a bit.
cobrapatrol Avatar
Quartz Hill, CA, USA   USA
I'm wondering if you've already done this? Adding a foam shim underneath the velcro at the front of the cantrail to fill the transition to the front frame? I'm also installing a new top and saw this in an installation here: Paul Rego's 74TR6.com site and wondered whether the intent was to help fill that gap.
Jim Harris
Quartz Hill, CA
My issue is my door glass does not touch the very front of the rubber seal that attaches to the bottom of the top side rails and the windshield post. There's a triangular gap. The only way I can get the glass to seal is raising the window up past the Velcro and aluminum channels. It seems the top frame needs to go up higher in the center or both door glasses are cut wrong. It might be easier to make a template and have the door glasses cut locally to match my car. If both of the top side rails were curved, the glass gap may not be a problem. Thanks for any ideas.
20171203_182111-1.jpg    22.7 KB
20171203_183307.jpg    16.9 KB
20171203_182111.jpg    16.9 KB
20171203_183307-1.jpg    20.3 KB
hogan1945 Avatar
Woodbury, MN, USA   USA
1968 Pontiac GTO "Tempest"
1976 Triumph TR6
1976 Triumph TR6
1976 Triumph TR6    & more
I would look at looseing the front window mounting bolts in each corner. Then readjust the window frame to better match up to your side windows when there rolled up. Also try readjusting your door window channels
to level your window glass.
Good luck
Besides the gap at the front of the glass, the middle part of the glass is too as well as the back part of the glass. When rolled up enough to get the front part of the door glass to seal, the glass is halfway up the Velcro strips on frame side rails. Something easy I probably overlooked but it's consistent on both sides. I may see how much it will cost to have new glass cut to match. Thanks for the reply.
skootch13 Avatar
skootch13 Aaron K
Cincinnati, OH, USA   USA
I can't imagine that your glass is made incorrectly and would need to be cut to make it work. There are adjustments that can be done to the windows and here is a great thread discussing some things that can be done.
pay attention to post #19
http://www.6-pack.org/j15/index.php/forum/15-mechanical-repair-maintenance-a-restoration/247462-How-to-square-up-windshield-frame-question?start=15
Maybe the glass isn't centered in the bracket that holds it?
1972 Sapphire Blue TR6
1999 BMW Z3 2.3
Edited 1 time(s). Last edit at 2017-12-05 01:53 PM by skootch13.
I replaced both windows with new channels, tracks and regulators. Centered both glasses in the channels before gluing them in with urethane. I raised the top frame at the 3 screws on each side today and it didn't change much. The gap is 3/4" at the front of the glass when the window is raised until it is in the middle of the rubber seals.
If I raise the windows fully, it's above the Velcro strips but there is no gap in the front. I'm thinking of having new door glasses made.
20171205_193648.jpg    30.7 KB
bikeboy Avatar
bikeboy Silver Member Ian F
In reply to # 1501416 by skootch13 I can't imagine that your glass is made incorrectly and would need to be cut to make it work. There are adjustments that can be done to the windows and here is a great thread discussing some things that can be done.
Well, this is EXACTLY the reason my RH glass wouldn't seal properly against the top. I only found out when I replaced both windows because they were a bit scratched. First pic is the large gap at the rear. Second pic is the difference in the cutting of the bottom edge.
window gap.jpg    79.5 KB
windows4.jpg    32.9 KB
Genoa Bay Eric Williamson
Genoa Bay, BC, Canada   CAN
So was your replacement glass original or custom?
Eric.
My drivers side window says Capital Glass on it like yours. My passenger side probably had it since I bought both at the same time but replaced the passenger side when I broke it drilling out the rivets for the snaps on the door. That window now has a generic Tempered Glass marking. I didn't use the door glazing strip when I installed my glass into the channels. I glued them in with 3M urethane like a modern windshield. I'm going to get 2 window glasses made. In reality the, tops of both glasses need to be cut and I can almost use them. My gap is in the front at the windshield post and top frame. I have a few used top frames I may compare my 2nd "new" top frame too and see if the top frame might not be the problem. Thanks for the info!!!
bikeboy Avatar
In reply to # 1502593 by Genoa Bay So was your replacement glass original or custom?
Eric.
Me? Mine are both stamped Capital Glass. Got them from Rimmers.
1962 Triumph TR4
