Convertible top frame rail spacing......
Charleston, SC, USA   USA
I'm transferring over my convertible top frame webbing from an old frame to my new top frame and was wondering if anyone knows the correct spacing of the rails. My spacing is: 13.5" from header panel to 1st rail.....10.5" from 1st rail to 2nd.....11.5" from 2nd to 3rd rail and 16" from 3rd rail to rear panel. Anyone know if these are close or correct? The webbing has the holes drilled in these locations. Thanks!!!
DerekM Avatar
Toronto, ON, Canada   CAN
I followed these instructions when I rebuilt mine http://www.buckeyetriumphs.org/technical/TR6Top/TR6SoftTop.htm
Derek McAllister
Toronto, Ontario
I saw those instructions and a few others but was wanting to see if I can re-use the webbing since it looks fairly new but the top was trash. I guess I could measure the distance between the seams on the new top to determine where the rails need to be located and see if the seams match the rivet holes in the webbing
ed.h Ed Hollingsworth
Omaha, NE, USA   USA
When I tried to use my old webbing as a pattern for new webbing, it came out too long. Obviously the old webbing had stretched.
Ed
Yeah I thought of that but the webbing looks pretty new. I'm going to measure the new tops seam locations then use those numbers to compare and decide if the 'new' webbing can be re-used. Thanks!!
Omaha, NE, USA   USA
The measurements on the Buckeye site put my bows right on the seams.
Ed
1957 Triumph TR3A
