carb leak
bassack42 Avatar
bassack42 Silver Member Steve Henderson
Newport News, Virginia, USA   USA
1974 Triumph TR6 "Maggie Mae"
Had a leak in my front carb. Took both carbs off as a set, r/r the needle valves (the old ones did not appear to be stuck), r/r gaskets, r/r floats. Cleaned carbs up. I will be putting them back on this weekend. My question is...Are the brass plugs for the bowls supposed to be that loose? They seem to just pull right out. I am going to replace the o-ring, but jeez, they seem loose. Any things to look for while putting these carbs back on? And should I use non-ethanol gas from now on when I can?
Thanks....Steve
The brass on the 74 carbs float chamber plugs are similar to a bottle cap, a covering over the plastic body of the plug.
Sometimes the brass cap will be loose but the plug is tight...nevertheless, like a LOT of the rubbery components in the ZS carbs the O-ring seal around the plug does have a limited lifespan and the plug is actually loose because of the O-ring seal.
I can't say I've seen for myself where ethanol has been a contributing factor to any decomposition within the carbs per se that I've worked on.
My engine actually seems to prefer 89 octane 10% ethanol as opposed to 87 octane gasoline.
Edited 1 time(s). Last edit at 2017-11-16 12:02 PM by poolboy.
bassack42 Avatar
Thank you Ken....I have a huge kit of various o-rings and will find a good replacement and go with that. There is a gas station about 15 miles away that sells unleaded. I will fill it up over there I guess when I can. If not, I ain't gonna worry about it!!
Might be worth mentioning that not all O-rings are created equal. They come in different materials for different applications. The EPDM that is probably most common does not hold up well to gasoline (or gasohol); Buna-N (aka nitrile rubber, probably 2nd most common) works much better with most petroleum products.
http://www.efunda.com/designstandards/oring/oring_chemical.cfm?SM=none&SC=Gasoline%2C%20Automotive#mat
1147cc Avatar
Westminster, SC, USA   USA
2nd that!
You need to get some fuel purpose O-rings.
PM your address and Ill send you a pair.
In reply to # 1498338 by TR3driver Might be worth mentioning that not all O-rings are created equal. They come in different materials for different applications. The EPDM that is probably most common does not hold up well to gasoline (or gasohol); Buna-N (aka nitrile rubber, probably 2nd most common) works much better with most petroleum products.
Douglas Hansen
http://www.1147cc.com
bassack42 Avatar
Ok.....Thank you Doug for the O-rings. I bookmarked your website. The carbs are on, working, and most of all, not Leaking! Took her for a test drive (15 miles or so) and had no problems. I'll tell you what though, I think I can now take my carbs off and on next time with a lot less time and apprehension. Screwed up a few things, but then figured them out. Thanks to all of you for your help.
Steve, Virginia
j007 Avatar
j007 Joseph M
Madison, Ohio, USA   USA
Good job Steve, that's how we learn, ask questions and figure it out.
Joe
73 Triumph TR6
