76 tr6 EGR lite stays on after turning off ignition, kills battery, it is off when running.Anyone know why it is reversed?
johntg john gray
palm desert, calif, USA   USA
EGR dash lite is on after the ignition switch is off. Kills the battery if I dont disconnnect cable. Anyone have any idea, havent touched wiring lately.
When I first got my 6 about 10 years ago I simply removed the bulb. Then when I rebuilt my engine I replaced the 2-piece speedometer cable with a single cable and removed rev counter as well.
Tom Smith
1976 TR6
1974 Midget
Has to be a wiring mistake (or short between wires) somewhere. The EGR light should only get power from the ignition switch (through the 'green' fuse); it can be grounded by either the EGR counter or the bulb test relay.
1972 Triumph TR6
