Ignition Switch Take 2 (ignition switch)
74TR6Oshawa Marc Purcell
Oshawa, ON, Canada   CAN
Thanks for all the responses regarding replacing both the steering lock and ignition switch.
I have the parts out and the replacement parts arrived from Moss Motor. The new ignition switch is a slight bit different from the original. The new part, from Moss has a 4 pin connector but the original connector has 5. The male pin at the top of the new part is missing.
Questions
1 - Has anyone used a 4 pin ignition switch to replace the original 5 - pin?
2 - Does anyone know what the function of the 5th pin (the single male pin at the top) is used for?
Thanks everyone
DerekM Avatar
Toronto, ON, Canada   CAN
It sounds like you've purchased part 667-845 (https://mossmotors.com/switch-ignition-lucas?assoc=46109).
There is no wire for the ARV on this switch, but this can be ignored if you have removed that from your setup.
http://www.triumphexp.com/phorum/read.php?2,747382
Schematics with wire colours can be found here http://www.advanceautowire.com/
Derek McAllister
Toronto, Ontario
Edited 1 time(s). Last edit at 2017-11-08 08:26 AM by DerekM.
Thanks Derek
Is the ARV the anti run on value? I just purchased the car. I'm not sure if it's been removed. Do you know it's location?
DerekM Avatar
Yes, that's what I was referring to. It's located on the bottom of the carbon canister, which is attached to the passenger side of the radiator. There are power and vacuum lines that run to its location; if it has been removed you may see the wires still there but capped off. This page http://trf.zeni.net/TR6bluebook/26.php and others in the Roadster Factory Blue Book will be of use to you, as will repair manual(s).
Derek McAllister
Toronto, Ontario
Thank you for your help and the links.
1956 Triumph TR3
