Rocker (Sill) trim fixings
gr8britt Avatar
gr8britt Andrew Blood
Grimsby, ON, Canada   CAN
I removed my stainless steel trim that runs along the rocker (Sill) panel below the door and need to replace a couple of the fixings (big surprise that rust ate them!) but nobody I have talked to recognizes them.
Does anyone here recognize them and possibly head me in a direction where I can source them?
Andy
2017-10-20 18.39.39.jpg    25.7 KB
ng19delta Avatar
ng19delta Scott Roberts
Merchantville, NJ, USA   USA
I don't believe those are original to the purpose, unless they changed after 1974: Originally they had a large "cup-disk" which had a pop-rivet body, and simply fit into a hole, and the pop rivet fixed it in place..TRF trims page
You might try (Restoration Specialties if you want to try to find the same type... Download their catalog, and flip through it...
Scott
M. Pied Lourd Pied Lourd
ON, Canada   CAN
Here's what they should look like as described by Scott
Tush
image.jpeg    32.5 KB
gr8britt Avatar
Thanks guys,
The holes in my rockers are too big to try and use the pop rivet type now so I will have to find something different.
Scott, great resource for fasteners, cheers.
Tush, great reference photo. Keep those videos coming, very informative.
Andy
DerekM Avatar
Toronto, ON, Canada   CAN
Might you be able to use the ones in Tush's photo if you drill them an use a larger rivet?
Derek McAllister
Toronto, Ontario
gr8britt Avatar
In reply to # 1494391 by DerekM Might you be able to use the ones in Tush's photo if you drill them an use a larger rivet?
The holes are about 8mm diameter to take the fastener, might be an issue finding a pop rivet that size but I will take a look when the car comes back from the body shop (rusty rockers!)
Appreciate the advice.
Andy
tr6easyrider Avatar
tr6easyrider Joe S
Riverside, CA, USA   USA
Andrew, Is the body shop replacing the rusty rockers? If not, maybe they can braze the holes closed and you can drill new holes for the proper rivet clip, which is a blind rivet.
s-l1000 (Small).jpg    42.9 KB
tomshobby Avatar
tomshobby Tom Smith
Windsor, WI, USA   USA
I used 3M double sided trim tape on both my Midget and TR6 trim on the trim strips under the doors on the rockers.
3M trim tape It can be found at many stores that sell automotive supplies and is available in different sizes. It is also easy to trim to size.
Tom Smith
1976 TR6
1974 Midget
ng19delta Avatar
Fill the holes, and drill new ones...
Scott
1971 Triumph GT6 MkIII
