Cylinder head studs...replacement
Triumphal Al Ramsay
Nanaimo, Canada   CAN
Can you replace one or more cylinder head studs on a TR6 without removing the head. I just got it back together and one of them is stripped. I was thinking I could replace one stud at a time and therefore not need to remove the head. What. Is the recommend procedure for installing them...thanks
dsixnero Avatar
dsixnero Dan Colanero
Westville, NJ, USA   USA
Sure, as long as you can get it out. double nut or drill a hole and make a handle
1976 Triumph Spitfire 1500
