timing 1973 tr6
badgertr6 Avatar
badgertr6 mike c
manitowoc, wi, USA   USA
I also have a 73. I thought the vacuum retard was there primarily for emission purposes. When the engine reaches a certain temp, the sensor in the upper radiator hose kicks in, and applies vacuum to retard the timing, which I think will lower engine temp. Unless you are trying to time the engine with a very hot engine, I would think the the retard is not in play, and it shouldn't make any difference if it's working, disconnected, or whatever. Set the timing at 4 ATDC and call it good, regardless if you are using the retard or not?
That's not exactly right, MikeC.
The Thermostatic Vacuum Switch, in the top radiator hose, blocks the vacuum to the retard module if the coolant gets too hot. ...the result is that the ignition timing advances causing the engine IDLE speed to increase, making the coolant circulate faster and if you have the crank driven radiator fan it also runs faster.
badgertr6 Avatar
badgertr6 mike c
Wow did I have that wrong...but of course I read my explanation on the internet one night and I always believe everything I read on the Internet......
gbtr6 Perry Rondou
If the shaft wobble isn't too great, try Pertronix electronic ignition. I have it and it works great. Not a substitute for a completely shot distributor, but it is not susceptible to the worn shaft wobble.
Perry
1980 Triumph TR7 Drophead
