Need to replace steering column bushings
gr8britt Avatar
gr8britt Andrew Blood
Grimsby, Ontario, Canada   CAN
Just changed my steering column bushes with the column in place, was a struggle but I got there. Used the steering shaft to slide hammer the top one out after cutting the buttons off then took a hand saw to the bottom and made 2 cuts along the length of the bush. Used a coach bolt to then pull it out.
Just pushed the new ones in with the help of some lube.
Andy
Statik Timothy Kunz
Baden, PA, USA   USA
I have to change my bushings as well.. I just emailed Art, Ill let you know how it went
