Triumphs List Archive
stuck TR4A bonnet
mailbot Avatar
mailbot Mail List Archive Bot
The Interwebs, USA   USA
Mail From: carlsereda <(email redacted)>
Peter,
Guessing a little here - the head of bonnet plunger may have not been
centered exactly and is snagging off to the side of its receiving
hole.
You might try having someone pull both release cables whilst you
firmly jostle the bonnet around by the eyebrows (attempting to jar the
plunger forward and back, and side to side, to uncatch head of plunger
from side of hole.. otherwise you may have to start taking things
apart behind cubby box to do the same..
Good luck,
Carl
'63 TR4 since '74
On Aug 30, 2010, at 11:00:03 AM, (email redacted) wrote:
Pulled the bonnet release cable today and much to my dismay the bonnet
did not
open.
I then reached for my backup cable and still no good.
Both cables have tension on them and I believe I hear the latch move.
I find it hard to believe both would fail simultaneously.
I have tried to push down on the center of the bonnet near the latch
but no
there is no play or spring whatsoever.
I'm suspecting the spring has gone out of alignment(?).
What would you recommend as next steps?
(email redacted)
Donate: team.net/donate.html
Archive: team.net/archive
Forums: team.net/forums
1972 Triumph Spitfire MkIV
