Triumphs List Archive
TR2 rough running update
mailbot Avatar
mailbot Mail List Archive Bot
The Interwebs, USA   USA
Mail From: John Gillis <(email redacted)>
Further on from my rough runing engine that would not rev out and had low
vacuum
readings, while preparing to remove carbs and manifold to check for leaks I
discovered the float in the front carb was full of fuel, this should not be
the
cause of my problems, but ordered a new float, popped it in and......well it
starts, with a bit of coaxing when cold, but now ticks over and revs out once
warm, don't know why the float should have affected this?. Now the runing and
reving engine is popping alot through the carbs and the exhaust, also using
the
lifting pins on the carbs only ever lowers the revs, ie too rich and no
adjustment seems to change this. I fell I'm getting closer but still need
help.
John Gillis
Senior Conservator
(email redacted)
Donate: team.net/donate.html
Archive: team.net/archive
Forums: team.net/forums
mailbot Avatar
Mail From: Anthony Cascio <(email redacted)>
Hi Jihn,
Not that I am an expert, but I can tell you about my most recent problem which was very similar to yours.
Mine carbs have the vent tube on to of the float bowls and it had the wrong gaskets on it. it needed the bottom gasket to have the three little cutouts on it so the bowl can vent. My rear bowl was staying full and it drove me patzo for over a year.
Hope this helps.
Tony Cascio
58 TR3A
TS27093L
(email redacted)
(email redacted)
mailbot Avatar
Mail From: "Randall" <(email redacted)>
> Now the runing and
> using the
It's the other way round, John. If lifting the pin only drops the rpm, then
the mixture is too lean. The backfiring is also a symptom of being too
lean.
Unscrew the mixture nuts by 2-3 flats and check again, I think you'll find
it's better.
If it was too rich, then lifting the pin would cause the engine rpm to rise
and stay up. Ideal of course is when it rises a bit and then falls back to
where it was.
-- Randall
(email redacted)
mailbot Avatar
Mail From: "Bob Nogueira" <(email redacted)>
Randall,
In all my reading I've always seen the phrase " ...ideal
rises a bit and then falls back to where it was."
What I've never seen is how much is a 'Bit'? Can you put
RPMS to that or is it so small that I would not see it on a tach?
Bob
> > -----Original Message-----
> > think you'll find it's better.
> > engine rpm to rise and stay up. Ideal of course is when it
> > -- Randall
(email redacted)
mailbot Avatar
> What I've never seen is how much is a 'Bit'? Can you put RPMS to that
> or is
I've never tried to watch the tach at the same time, Bob. But I would guess
that we are talking about perhaps 50-100 rpm increase. The change is quite
apparent to the ear, but I suppose that would not help if one were deaf or
whatever. The increase is rather brief, though, so I'm not sure how well it
would show up on a digital tach. The main thing is that it winds up where
it started, rather than distinctly higher or lower.
-- Randall
(email redacted)
1970 Triumph GT6 MkII
