Spitfires List Archive
New tank - slight hitch
mailbot Avatar
mailbot Mail List Archive Bot
The Interwebs, USA   USA
Mail From: (email redacted)
With some elbow grease, I got the new fuel tank in, but with one hitch. Always a hitch with new parts.
The Fuel filler cap doesn't fit on quite right. At best, it sticks out a third of an inch from where it should be. It seems the fuel filler neck on the tank is a bit far forward. Did my best to fit things together so as to no fuel leaks when I fill-up, but I think I can do better. I'm not sure if the neck is exactly advanced forward a bit too far, or at some weird angle where the back of the neck area isn't giving the filler cap enough room. Tried loosening the top bolts to change the angle a bit, to no avail.
In theory, could one put some washers as shims to overall move the tank back a bit to line things up right? That's gonna be fun on some of the hard-to-reach zones between tank & car for bolt holes.
(email redacted)
Donate: team.net/donate.html
Archive: team.net/archive
Forums: team.net/forums
mailbot Avatar
Mail From: "Joe Curry" <(email redacted)>
Not only can you fit spacers, but you should. I would recommend that they
be made of rubber to absorb vibrations to keep the thing from shaking the
seams and self destructing.
Joe
-----Original Message-----
[mailto:(email redacted)] On Behalf Of (email redacted)
Sent: Friday, June 11, 2010 5:32 AM
To: (email redacted)
Subject: [Spits] New tank - slight hitch
(email redacted)
Unsubscribe/Manage:
autox.team.net/mailman/options/spitfires/(email redacted)
(email redacted)
mailbot Avatar
To clarify, you are referring to rubber spacers involving the bolts that hold
the fuel tank together? Guess I need to do some part hunting for something
suitable.
----- Original Message -----
To: (email redacted), (email redacted)
Sent: Friday, June 11, 2010 10:18:32 AM GMT -06:00 US/Canada Central
Subject: RE: [Spits] New tank - slight hitch
Joe
(email redacted)
