6Pack TR6 List Archive
Latest on my Hayden fan
mailbot Avatar
mailbot Mail List Archive Bot
The Interwebs, USA   USA
Mail From: Joe Honor <(email redacted)>
Ok always good to check all connection-and see they they all actually have
power load etc my ignition-continuous power to the fuse box was hooked up to a
non powered lug both from accessory and when ign is on once changes to a
tested hot lug voilC ! All works as it should engine gauge shows hot I will
swap out sender to see I'd that matches what me be real thanks everyone!
Regards Joe
(email redacted)
Donate: team.net/donate.html
Archive: team.net/archive
Forums: team.net/forums
mailbot Avatar
Mail From: (email redacted)
I guess you mean you were checking it all along with the key off all along.
Personally I have mine wired to turn off power with the key so that it is off and not coming on when I am working under the hood.
Don't think that there is any benefit for the fan to run until the rad cools off if the water pump is not circulating the water.
Lou
72 Pimento
------Original Message------
Sender: (email redacted)
To: TR-6 list
Subject: [6pack] Latest on my Hayden fan
Sent: Aug 25, 2010 2:21 PM
Regards Joe
(email redacted)
Unsubscribe/Manage: autox.team.net/mailman/options/6pack/(email redacted)
(email redacted)
mailbot Avatar
Lou I agree with that set up. it was inadvertently setup by the prior owner to the incorrect fuse lug that had no continuous power when on acceessory. just put 80 miles and all OK. running abit hot suspect my temp sender. will wait fo rnew aluminum radiator with related thermatate etc to see how it then before investigation. Thanks. regards, Joe
----- Original Message -----
To: "Joe Honor" <(email redacted)>, "TR-6 list" <(email redacted)>
Sent: Wednesday, August 25, 2010 5:41:05 PM
Subject: Re: [6pack] Latest on my Hayden fan
Lou
72 Pimento
To: TR-6 list
Regards Joe
(email redacted)
(email redacted)
1970 Triumph GT6 MkII
