6Pack TR6 List Archive
Wiper Switch Repair
mailbot Avatar
mailbot Mail List Archive Bot
The Interwebs, USA   USA
Mail From: Sally or Dick Taylor <(email redacted)>
List---Several months ago one on this list went to a great deal of trouble to
show us how he repaired his wiper dash switch. (The one that also contains the
washer momentary switch) I thought I had placed his drawings in a "Saved"
file, but now cannot find it. If someone has a copy of this, or the originator
would be so kind, I'd like to see it again. This time I will print it out!
Thanks.
Dick
(email redacted)
Donate: team.net/donate.html
Archive: team.net/archive
Forums: team.net/forums
mailbot Avatar
Mail From: Douglas Morris <(email redacted)>
Dick,
I emailed my pics to you directly, but for the record I'll repost.
The fix still works fine.
>From Dec 8, 2009:
QUOTE
Okay, here's what I did to fix the wiper-washer switch which was rotating with
the knob. I epoxied a flat washer onto the switch body between the gray cup
and the switch body and installed a #8 set screw to act as a pin all the way
through the cup, washer, and case of the switch body. Caution: I drilled the
body for the set screw near the contacts, but there are moving bits just
inside the case of the switch body, so that pin must not extend past the inner
case surface, or the switch won't rotate. Next time, I'll try drilling the
hole on the opposite side from the contacts. Might not be anything there.
Dunno. Not curious enough to go drill another hole, though. Note: the shoulder
on the shaft boss (where the center hole in the flat washer sits) is about
5/8" so I Dremmelled-out a 1/2" washer to fit. Gotta work with what you have
on hand.
img31.imageshack.us/img31/9012/wiperswmods.jpg
In order to get the nut off and on without bungin' everything up by tryin' to
do it with a slotted screwdriver, you need to make a simple/cheap tool. There
are a number of approaches, but I made a simple spanner. The nut has slots, so
I modified one end of a short PVC pipe making little protrusions I'm callin'
"nips." Heat-treated steel would be better, but the PVC piece was sittin' in
my trash box, so ...
img35.imageshack.us/img35/9302/wipertool.jpg
Actually, I think the simplest approach would be to cut a piece of sheet
metal, put it where I put the flat washer, then bend some ears over on both
pieces.
Maybe a couple star washers would work. Dunno.
Everything checks for isolation/continuity, so I'll put the switch problem
aside and work for a while installing the exhaust. When I figure out where to
mount that intermediate hanger, I'll post a pic.
Doug Morris, NC
'74 TR6 w/OD
/QUOTE
(email redacted)
1968 Triumph TR250
