6Pack TR6 List Archive
Carb Rebuild Story
mailbot Avatar
mailbot Mail List Archive Bot
The Interwebs, USA   USA
Mail From: "(email redacted)" <(email redacted)>
After just shy of 2 months at Paltech in Ohio, I received my carbs and
manifold back this week. What a relief to find that they ran great right out
of the box. The workmanship and finish are exemplary. If you can afford the
down-time and need similar work done, I highly recommend this company. Those
on the list that recommended this company to me were right. My only
complaint was that the shipment packaging was no where near the quality I
would expect for my delicate and pricey cargo. Pictures of carbs and
manifold on my Facebook page.
On a different note, FYI I was able to cure a long-time differential clunk
problem by replacing the side gear bushings (now fiber) and planet gear
bushings (brass) to tighten up this part of the gear train. Installed
pinion/crown gear backlash is .005 average. I was also able to replace a
single cracked carrier bearing cap (I received an entire used unit from Ted
Schumacher - another one I highly recommend). I got lucky because one of the
caps on the unit I received was almost exact in critical dimensions to the
cracked one. I think I dodged a bullet, but time will tell.
Brian J. Alwin
1972 TR6 CC79085
(email redacted)
Donate: team.net/donate.html
Archive: team.net/archive
Forums: team.net/forums
mailbot Avatar
Mail From: "Bob Danielson" <(email redacted)>
I found Jeff back in '06
(tr6.danielsonfamily.org/CarbRebuild2006.htm) and have been
recommending him ever since. He does a super job on both the refinishing and
the rebuilding.
Bob Danielson
1975 TR6 running with
Throttle Body Injection
Toyota 5 Speed
Nissan Diff & CVJs
Sent: Saturday, August 07, 2010 6:43 PM
To: <(email redacted)>
Subject: [6pack] Carb Rebuild Story
> out
> the
> Those
> Ted
> the
> Brian J. Alwin
> 1972 TR6 CC79085
> (email redacted)
> Unsubscribe/Manage:
> autox.team.net/mailman/options/6pack/(email redacted)
(email redacted)
mailbot Avatar
Mail From: Bob <(email redacted)>
> out of the box. The workmanship and finish are exemplary. If you can
> afford the down-time and need similar work done, I highly recommend this
> company. Those on the list that recommended this company to me were right.
> My only complaint was that the shipment packaging was no where near the
> quality I would expect for my delicate and pricey cargo. Pictures of
> carbs and manifold on my Facebook page.
> the caps on the unit I received was almost exact in critical dimensions to
> the cracked one. I think I dodged a bullet, but time will tell.
> Brian J. Alwin
> 1972 TR6 CC79085
Brian,
I decided to go with the Hitachi SU HS6 upgrade offered by Jeff.
I posted a photo on the 6-pack list.
6-pack.org/sixpack/phpbb2/viewtopic.php?t=15146&highlight=
Scroll down to you see the post with the engine bay in French blue with the
yellow TR3 and white TR4 avatar. That is me.
I agree with you, Jeff sure does nice work.
And yesterday I finally completed enough of the wiring of the dash to give the
engine a start and it started right up ran pretty good for a freshly rebuilt
engine, dist, and carbs. Still needs some sorting out but that will happen
when I can get it out of the garage.
Bob
(email redacted)
1980 Triumph Spitfire 1500
